Curious about my numbers
Thanks
Chris
Thanks
Chris
The thing you don't see is the other 50% of the members here not posting there #'s which are just like yours
Your #'s are respectable,between the 12 bolt and your probly missing some bolt-ons which add up. No biggie.
Thanks
Chris
From what i have seen this seems to be the spread. The research is in dynojet can vary on the lowside i would say at least 10% and a high of 20% depends on the dynojet since they all vary with each other as much as 7%. The mustangs we have checked at least all the local ones. they seem to be within 1-2% of each other. Granted weather can play a factor for sure. Someone should start a thread comparing dyno sheets vs timeslips and see how this adds up.just an idea.
And believe it or not those numbers you have calculated add up like they normally do.
Edit:
Whats really interesting is that were are seeing a trend to higher % difference between the mustang and the dynojet as power goes up. Could be due to the fact that mustangs most anyways are loaded dynos that sort of control the step rate and dynojets most of them are pure inertia and show acceleration a bit better. could be the reason for the disparity, Could also be that dynojet dynos just don't properly calculate power.
I don't know but if my car ain't pushing at least 400hp Im goin to tatal that bitch.
lol!I do have the ls6 intake.
I am not sure what u mean by hanicapped?
