VIDEO at Idle plus streetability and WOT with my 511rwhp / FTI
Old 08-04-2008, 11:45 AM
  #141
miami993c297's Avatar
Originally Posted by 99Ls1fever
What heads are you running?
Hi 99Ls1fever,
The heads on my engine are the ETP 215 @ 60cc prepared by FTI:
Christian
Old 08-04-2008, 05:33 PM
  #142
98camaroLS1M6's Avatar
They are a good set of heads if you can find them. I'm impressed by the 455rwtq!
Old 10-08-2008, 02:32 PM
  #143
It is certainly one of my last post in this thread as the engine is going to be a LS3 Stroker Short-Block by Erik Koenig and the Cylinder Heads ETP by FTI Ed Curtis hand ported very soon...
I am duplicating a post from this morning from another forum where I was answering a technical question.
Here is how I did tune this engine, and how I extract the most of it.
All the tests have been operated on the same road, same starting point, all engine temperature monitored and similar in a window of 5°F, same wheels and all the parameters that could affect performance as much as possible under control.
Acceleration is monitered in 4th gear which is ratio one on this Corvette.
I use an accurate weather station for all my passes.
With each test I produce an electronic Acceleration Sheet as below:
Timing is closely linked to AFR to obtain the best results, then I will provide both data to make it accurate.
Max Torque is at ~4400rpm, Timing is 21° and AFR is 12.40:
Max Power is at ~6400rpm, Timing is 25° and AFR is 13.20:
One item that was impossible to work on with a Dynojet was the Power in High Revs, on the road the results are significant in this zone.
Timing is 26° and AFR is 11.90 at ~7200rpm:
The Timing table is looking nice and is optimized for drivability as well, it took a lot of method and was time consuming:
Christian
Old 10-09-2008, 09:03 AM
  #144
allngn_c5's Avatar
Can't wait to hear about the power you make from your new motor CB !!
Good luck to my favorite uncle. LOL
Old 12-08-2008, 01:58 PM
  #145
I couldn't let this thread go without a last important update...
Engine has been taken apart and in the final process to reborn 416CI...
NONE of the 8 pistons have any signs of contact with the valves, and I have recorded 9 over-revs to 7600rpm and an amazing amount revving to 7500rpm!!!!
This combo rocks.
Christian
Old 12-08-2008, 02:30 PM
  #146
Chris05ssTruck's Avatar
Where the hell was ur rev limiter? Non existent? Stock rod bolts? That high? Ur crazy lol.
Made damn good power. Can't wait to see the new set up!
Old 12-08-2008, 05:33 PM
  #147
GMCHammer's Avatar
Old 12-09-2008, 11:18 AM
  #148
allngn_c5's Avatar
Hey Christian, so where are you at on the 416 ??
Old 12-09-2008, 02:19 PM
  #149
Hi Doug,
The engine is a product of both Erik Koenig and Ed Curtis, working together to give me the closest of what I was asking.
Attention to detail was high, very high!!!
Low friction crankshaft assembly, low friction rings, customs pistons, valvetrain up to tip-top, custom camshaft using specific lobes, and always hydraulic, ETP cylinder heads upgraded for more cubes and reworked...+++...
The long-block was assembled by Erik in his shop, and shipped last Monday from Texas; it will be soon in Florida;
I will keep you updated, in another new thread...
Christian
Old 12-09-2008, 04:21 PM
  #150
Hi Chris05ssTruck,
About rev limiter and high revving take a look at post #97 and post #99, tried to explained there...
The short-block was stock except a re-ring by GM under warranty...and the KATECH rod-bolt at this occasion for a peace of mind!!!
Thanks for the props...
Christian
Old 12-10-2008, 09:28 AM
  #151
allngn_c5's Avatar
Originally Posted by miami993c297
Hi Doug,
Christian
Thanks for the update Uncle C !! I am very anxious to see how your new motor does. Any ideas as to how much power she could make ??
Old 12-10-2008, 01:28 PM
  #152
That 346 was a very strong motor, good luck with the new setup!!!
Old 12-11-2008, 04:51 AM
  #153
allngn_c5's Avatar
Just watched the vids again Uncle C. Still as cool as the first time I saw the run to 185 !
Old 12-11-2008, 04:42 PM
  #154
pitbull14218's Avatar
Everytime i try to watch these vids they arent even getting to the page...
Old 12-14-2008, 01:12 PM
  #155
99345hp's Avatar
Patrick G, I will probably be contacting you about specing me a camshaft after the new year. I have read so much about cams on here I think im going crazy. I want two different things that contradict themselves, so I dont know what I need.
sorry about the hijack.
Old 12-14-2008, 02:05 PM
  #156
OUPS,
My thread is about Ed CURTIS Camshaft if you read it...but Patrick G is an excellent option...
Christian
Old 12-14-2008, 08:11 PM
  #157
99345hp's Avatar
well, maybe since your car is so streetable with his cam maybe I will go to him for advice. I read bits and pieces of the thread and I watched the videos.
Old 12-14-2008, 09:35 PM
  #158
Shoot me a PM and I will redirect you on his forum where you will have the opportunity to ask your camshaft questions...
And I hope you appreciate the videos!!!
Christian
Old 12-15-2008, 01:16 AM
  #159
studderin's Avatar
just stick with one guy, youll make everone and yourself happer. I'm really happy with my FTI cam, ed knows his stuff.
Old 02-14-2009, 03:16 PM
  #160
As it wad questionned in another thread, here is a picture of the three pieces pushrods used in my engine:
Christian
Quick Reply: VIDEO at Idle plus streetability and WOT with my 511rwhp / FTI
