dyno sheet questions
Old Mar 12, 2007 | 02:34 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default dyno sheet questions
so heres my dyno sheet from about a week ago why does my power drop off so early mods in sig
Old Mar 12, 2007 | 10:51 PM
Tuner@Straightline's Avatar
How much timing do you have? Stock cam car usually pull to about 6000-6200rpm before falling off, and by 6200-6400rpm start falling, if not earlier, depending on how well the exhaust is breathing and gearing.
Old Mar 13, 2007 | 01:59 PM
LS1Tech Sponsor
well the exhaust is a 2 1/2 td setup no mufs im not sure of the spark
Old Mar 13, 2007 | 03:13 PM
How many miles on the car? Clutch could be starting to slip.
Old Mar 14, 2007 | 01:35 AM
BLKWS.6's Avatar
Graph looks fine to me...
Old Mar 14, 2007 | 04:01 PM
98NATA's Avatar
Not to hijack, but taking your car to the rev limiter, when stock, doesnt necessarily increase your peak numbers because the power is dropping off by then, am i correct in assuming this?
Old Mar 14, 2007 | 04:07 PM
lsx24's Avatar
Stock ls1 (with the stock cams) usually peak at 5.5k, so yours is perfectly normal.
Old Mar 15, 2007 | 02:09 PM
BLKWS.6's Avatar
+1, there was a stock one with 118K miles that peaked at 5300 or so. Graph is posted in my "high mileage dyno" question thread. Made 306whp though so dont knock it.
Old Mar 15, 2007 | 11:01 PM
LS1Tech Sponsor
96k miles 4k old ls7 clutch
