Disappointing results with TFS Heads
Not to be rude, but can you please continue this discussion via pm's or with a different thread? It's hard enough trying to get a handle on what the heck is wrong with my car without two different conversations going on.
My Apologys. Just trying to understand why you had such bad luck with the same heads I am going to use. I don't want to make the same mistake. This is your thread. But it is a Public Forum.
He said overlap could be your problem & thus why i asked what it means & to prevent this problem on your car & others people setups
I would take the advice of Mike above...
Correction Brian, The other guy has PP- adjustable rockers.
https://ls1tech.com/forums/dynamometer-results-comparisons/681283-dyno-issues-tfs-headed-ls2-vette.html
I have heard the YT's need to be shimmed up about .050" to get nice geometry and use a 7.550" pushrod.
The 7.500" is now the correct length. The 7.700" was used on some of the early heads but they made a revision.
https://ls1tech.com/forums/showthread.php?t=681283
If anyone is wrong. It was me. please continue. I will post a new thread. Sorry.
Something else to add. Look at the cam used in the other thread:
https://ls1tech.com/forums/showthrea...3&page=1&pp=20
Seems like a very similar cam.
Or shim the current setup to reduce preload a bit?
OK so the exhaust is restrictive then on this setup. So it's sounding like swap the cam and replace the rockers would go along with the 2 main trains of thought here. What exhaust are you running? long tube 1.75" or better?
I would suggest some log runs so you can give us some figures. My first though was to say the intake, but with your old heads and the Ls6 intake you should have been up near the 450s. Now if you had those rockers on with the previous heads it is possible something is up with the geometry. I was also looking at the exhaust and cannot find FLP headers for a C5. Do they come with a X or Y pipe? What is the pipe size back to the catback? I do not think the stock air bridge is holding you back that bad. I know Allan has done a car or two with the F14 slightly larger cam, and had no problems making over 480 rwhp with the TFS heads. I would look for some simplier solutions before you take the cam out.
Do you recall if he make that kind of power with a 112 or 114 LSA cam? Rockers were on for both runs.
Question: Would the fact that he has no advance on a 112LSA cam have anything to do with this?
