Disappointing results with TFS Heads
So this spring I installed a set of Trickflow 215's milled to 61cc. Here is the result:
Yup 5rwhp/2rwtq which was disappointing to say the least.
So I'm not sure where to go next. The car has had it's last 2 tuning sessions with Dan at FLP, so the tune is not suspect (it runs hard and drives great). I asked him if it looks like there was any valvetrain instability and there doesn't appear to be. I triple checked my pushrod measurements when installing (ended up with a 7.5" pushrod since my TFS heads are milled to 61cc).
My gut tells me I am looking at a restriction someplace. The cam and heads should have each yielded at least a modest gain, but instead I'm only seeing minute changes. The exhaust with Corsa Indy's and catless Longtubes doesn't seem likely. The cam isn't huge, but judging from others results and the specs I would think it should support some decent power. My only thought at this point is that the stock MAF/airbridge/TB and the LS6 intake are starving the engine of air. But before I contemplate sinking more money into this thing I'd really like some opinions on what could be holding this combo back.
Something must be wrong there, don't you think?
Christian
I would take the advice of Mike above...
I am running the TFS 225 Heads on a 347 Motor with a 648 - 652 Duration Cam on a 110 Lobe Sep at 650 lift, Nick William TB, FAST Intake (ported), Kooks 1 7/8 headers Stepped 2inch on 3 1/2 Collectors with a 3 1/2 inch Custom X-Pipe with Elec Waterpump & pulley through a Stage 3 Built 4L60E Trans with a Yank PT 4400 converter,on a 12 Bolt.
Any thoughts on what I can do to help out this combo. I am looking to make 440 RWHP
Sorry to the thread starter. I didn't mean to Hi Jack your thread
Seb
It would have picked that up with his old heads also.
Seb
Thats a big *** cam for a 347.
I dont think it needs to be that big to make 440rwhp.
Seb
248-252 duration.
I am wanting to make good TQ & that is why I am going with a 110 lobe sep. It just going to be really hard to tune from what my tuner says.
Looking to run 6.80 @ 101 mph in the 1/8 mile. The car is Full weight at 3600 lbs,,,,
Am I setting my goals to high.
Also I am wanting to run the Jessel rockers
Not to be rude, but can you please continue this discussion via pm's or with a different thread? It's hard enough trying to get a handle on what the heck is wrong with my car without two different conversations going on.
installing 215's on my car tommorrow, wanna keep track of this thread
