Torquer V.1, Dart 205, FAST 90/90
Mods are as follows:
Torquer V.1 - 233/233 .589/.589 112
Out-of-the-box Dart 205's
GM MLS Head Gasket
Ford SVO 42# Green Tops
Pacesetter LT's
TSP Duals
Surprisingly enough, the earlier, leaner run made more power and torque across the board. I think either the WBO2 sensor was out of whack or I possibly have an exhaust leak somewhere. Anyhow, I richened it up a bit to be safe regardless of the slightly lower numbers. I was only able to get a 6 runs in, so I'm sure if I would have had more time I could have squeezed a bit more out of it, but I'm satisfied for now.
Here's my peak run over my previous cam-only numbers:
So, I gained about 35 HP and 20 Ft-Lbs peak.
I'm surprised I didn't pick up more down low, because it sure feels like it did. It's probably the greatly improved throttle response that makes it feel that way. With my mods I think I'm right where I should be power-wise, so I'm pretty happy.
My next step is going to be to spec out a custom cam and swap out my aging Pacesetters for some QTP's.
And many thanks to the guys at NewEra! They hung out late so I could get on the dyno! Thanks guys!
GM MLS Head Gasket
Pacesetter LT's
TSP Duals
Originally Posted by Mr.MartyStone
Great numbers man. Didn't you live in the NW previously?
Marty
Marty
ya i got a torquer v2, PRC 5.3L heads, and a LS6 intake and i out down 434 SAE.
Those are some pretty solid numbers you got there.
I need to get a 90/90 to accomodate my better flowing heads.
Good job!
Good job!
