D-1sc with stock bottom end
Old Jul 25, 2007 | 02:20 PM
  #41
onefastss223's Avatar
How much timing is the car running? If he hasnt changed his tuning any since tuning my car, expect a blown head gasket soon. I bought my car out of St Louis and the tuning was done by him. Blew a head gasket the 2nd day I had it b/c the timing was 24* on pump gas with no alky/etc(CR~9.8:1). Just a heads up for ya though. Nice track time also....
Old Jul 25, 2007 | 09:07 PM
  #42
d-1sc408's Avatar
23 degrees of timeing on pump gas
Old Jul 26, 2007 | 06:26 PM
  #43
nastysupaspt's Avatar
Dude!!!!!!!!!!!! Awesome 1/4 Mile Time And Sick Mph!!!!!!!!!!!!!!!!!!!
Old Jul 26, 2007 | 08:10 PM
  #44
Josh@MASPORT's Avatar
Closed Sponsor Account
please be careful with that! people destory there stock bottom ends with 500RWHP
Old Jul 26, 2007 | 09:17 PM
  #45
Sharpe's Avatar
Here's just a wild guess from way out in left field: i don't think he's too damn worried about the bottom end.
Old Jul 26, 2007 | 09:39 PM
  #46
d-1sc408's Avatar
im just having fun with it
Old Jul 26, 2007 | 09:47 PM
  #47
98camaroLS1M6's Avatar
nice power!
Old Jul 27, 2007 | 02:25 AM
  #48
u got that extra short block hanging out in the garage i suppose? or at least a second car? haha
Old Jul 27, 2007 | 08:29 PM
  #49
beardWS6's Avatar
With your times, makes me feel good. I have over 700rwhp and want 9`s. Great numbers!
Old Jul 27, 2007 | 08:43 PM
  #50
Frost's Avatar
A 12:1 AFR and 23degrees on pump gas and NO meth? I bet it does run strong, that's waayyyy past where I would push it. With no meth a lil heavier AFR would hold off knock easier... That setup may make good power through a pull of 1 gear on a dyno, but putting all 4 gears together like a track pass?? High IATs, high compression, and too much timing for even really a lower SCR than you have = borrowed time.
If it stays together long enough I'd be back at the tuner looking for a fatter AFR or adding meth (better, octane value + low IATs) and wanting that timing pulled back.
I'm not trying to sound preachy, but that has to be on the most ragged of edges right now unless that wideband on the dyno is off.
Old Jul 27, 2007 | 11:22 PM
  #51
d-1sc408's Avatar
I'm not trying to sound preachy, but that has to on the most ragged of edges right now unless that wideband on the dyno is off.
well af was like 11.5
Old Nov 27, 2007 | 05:10 PM
  #52
bigblock4-speed's Avatar
Good Times on 10 pounds of boost.. I just bought a d1sc car- 01 ss (stock bottom end)cam, ported heads, intake, etc.. twin intercooled. conservative 7.88 pounds. moser 12 bolt, bla bla.. owner ran once at track ran 11.14 @129 with a 2.45 60 foot.. ya he dont know how to drive.. should be a 10.40-10.60 car.. ? hope??
Old Nov 29, 2007 | 07:17 AM
  #53
GrannySShifting's Avatar
Its definitely going to pop, matter of when not if.
It comes on really late in the torque curve so that helps it a bit but
8 lbs of boost, pump gas and alot less timing than that is what we do and made 550/500 on stock longblock trapped 130, and made 630-640 with about 10 degrees less than what you have and full point richer almost. It survived about 70 pulls on our loaded Mustang dyno (you get away with ALOT on a dynojet) and beating alot on the street and road course. A blower car will pick up considerably leanign it out and giving it timing, but its not going to treat you right for long. Safen it up a bit and enjoy it much longer!
big block yeah Id expect low to mid 10s out of it, ifthe torque curve is healthy near 135 mph traps
Old Nov 29, 2007 | 09:54 AM
  #54
BADSZ28's Avatar
F*ck NA or N2O, I want a D! Just need the Dough!
Old Nov 29, 2007 | 11:42 AM
  #55
PewterScreaminMach's Avatar
Haha, this thread is from July. I wonder if he's still on that stock bottom end.
Old Nov 30, 2007 | 10:08 PM
  #56
d-1sc408's Avatar
ya the car is still runing good i actual went up in boost to 14 psi and the car made 728 and 618 but ya the car is still running like a ****
Old Dec 1, 2007 | 01:17 AM
  #57
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Yeah, I forsee either a hole in the piston or ringland failure in your future. Good results though.
Old Dec 1, 2007 | 05:27 AM
  #58
djsanchez2's Avatar
Damn that is just badass!!
Old Dec 1, 2007 | 05:42 AM
  #59
james562's Avatar
Anyone wanna get a pool on how long #7 will last???
Damn 10.15@134 thats moving the *uck out on a stock shortblock
Old Dec 1, 2007 | 08:01 AM
  #60
CALL911's Avatar
I have to chime in with the others that have their doubts that his motor will last. I have seen too many guys with great "safe" setups, and tunes time and time again on the stock bottom ends blow their motors by putting a forced induction application on with anything over 6#'s of boost.
These cars came with a high CR, and non-forged internals from the factory, even if you do all the supporting mods like a great fuel system, methanol injection, intercoolers, good safe dyno tune, its only a matter of time before you'll need a rebuild. It might make it 25,000 miles, or it might make it 2500 miles, but either way you are putting boost on a motor that just was not meant to take it from the factory, and something will give sooner or later.
Even with just 6#'s of boost, I highly doubt you'd see the same mileage out of the motor that you would if you stayed N/A.
I hope you proove me wrong though and your car will still be pumping out those numbers, and times with the stock bottom end for years to come. Good luck man.
