402/ D1SC Numbers
Old Jul 21, 2007 | 10:30 AM
E Wagz's Avatar
Default 402/ D1SC Numbers
Had the car Speed Density tuned at Speed Inc. on 7/19. Car made 675 RWHP/635 RWTQ at 13.5 psi. Forged 402/6.0L Iron Block. D1SC with 3.4 pulley. 6 Speed. 93 Octane. Very pleased and throttle response is smooth as butter.
Old Jul 21, 2007 | 01:34 PM
venom ws7's Avatar
Nice numbers What heads,cam do you have?
Old Jul 21, 2007 | 02:34 PM
E Wagz's Avatar
AFR 225'S; THUNDER RACING CUSTOM GRIND 224.2/232.9; .642/.595;114.8 lsa
CR IS 8.78:1
WANTED VERY STREETABLE SET UP(PRACTICALY A DAILY DRIVER)
Old Jul 21, 2007 | 05:49 PM
Gary98Z's Avatar
Nice numbers! Nothing like having a 675rwhp daily driver.
F1A in your future?
Old Jul 21, 2007 | 10:36 PM
helicoil's Avatar
Default 402
Nice results. Are you using a FMIC or the twin 4.5 ATI's?
Old Jul 22, 2007 | 12:17 AM
1ORANGEWS6's Avatar
Can you post up a graph?
Old Jul 22, 2007 | 09:35 AM
speedracer5532's Avatar
I have a 402 with AFR 225 heads but a F1A blower and I made 864 rwhp and 743 rwtq on 12 lbs of boost. I am kinda surprised that there is that much difference in power between the D1SC and a F1A.
Old Jul 22, 2007 | 05:25 PM
E Wagz's Avatar
Nothingreally inthe future forthis car except some dress up and some tranny upgrades....then on to the next car
Oh, and to answer the next, just the twin 3.5's for now, will likely upgrade to the 4.5's, started as a P1SC kit.....
Don'thave a scanner, will take a pic of the graph I guess.
I would imagine there would be considerable difference in the F1A, however what CR and pulleys are you using? I'm sure I could get considerably more HP with higher CR but it is a "street" car with extremely good manners and not to hard on gas as well. Next car may be a racer.
Old Jul 22, 2007 | 05:41 PM
E Wagz's Avatar
Graph not showing up worth a crap at any size the site will accept.
Shows max power of 675.78 at around 5700-5900rpm
Shows max torque of 635.11 at around 4700-4900rpm
lines cross at 5250 rpm
85 degrees/57% humidity/ SAE:1.05
Old Jul 22, 2007 | 06:07 PM
My CR is 9:1 and my car is also a street that I could daily drive easily if wanted. I am running the ATI 7.625 crank pulley with a 4.38 blower pulley.
Old Jul 22, 2007 | 10:52 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'd skip the 4.5s and just get a FMIC. Look at EPP's site, they have a kit for it or you can scavenge Ebay intercoolers.
Old Jul 23, 2007 | 12:04 AM
E Wagz's Avatar
gotta be that blower and the FMIC then speedracer, I'm very close to if not maxing out the D1.Sounds likeyou have a helluva car.
Have had afew messages exchanged with Bob already,thanks Beaflag. Don't know that I am up for the FMIC though.
