Torquer v.3 Reading a little low
Old Nov 29, 2007 | 09:12 AM
qwikz28's Avatar
Default Torquer v.3 Reading a little low
2002 Z28 M6
Mods:
Torquer v.3 Cam 111LSA
PRC Stage 1.5 LS6 heads
QTP 1 3/4 Headers
Custom Mufflex Catted-y
Corsa Catback
TSP Lid
Thunder Racing ported TB
LS2 portworks Ported LS6 intake
Yella Terra Rockers
7.400 Pushrods
stock water pump and pulley
4.10 Moser 12 Bolt
Steel driveshaft
Spec stage 3i with billet steel flywheel
Tuned by Eastside
Car has a wicked valvetrain tick that increases with engine speed. I'm assuming that has something to do with the low reading, Eastside suggested diagnosing by putting the stock rockers back on over teh winter. I figured i'd post up anyway maybe someone had other alternatives. Regardless of the fact, the car pulls like an animal and revs fast as heck. I'm not one to care for dyno numbers granted i'm extremely satisfied with how fast my car is now, but i'd sure as well love to fix that tick. Any input?
Jacob
Old Nov 29, 2007 | 10:20 AM
ls1muscle's Avatar
What valvesprings are you using? Are these the older rockers or the new ultralights? Are the heads milled any? Measure pushrod length?
The torquer 3 is very similar to my cam. Big lift on the intake needs the springs shimmed to .050 of coilbind as well.
Old Nov 29, 2007 | 10:27 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I'd try the other rockers & check preload, that definately seems about 50 low
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Nov 29, 2007 | 12:38 PM
JS's Avatar
JS
Something is wrong,U better go back over the PR length and Rockers...
Old Nov 29, 2007 | 02:35 PM
qwikz28's Avatar
i think its the pushrod length but i have no idea how to check. i bought a pushrod length checker, didn't know how to use it so left it to the side, and lost it.
the heads are milled only the slightest bit, .003". the rockers are the new ultralights and the springs came mounted on the heads as a package with the cam so i guess jason would be able to comment on that.
edit: i didn't check the pushrods, which is why i think they might be wrong with the milled heads and the aftermarket rockers. i'm pretty sure preload is fine because when i installed it, it ticked and when eastside installed it, it still ticked
Old Nov 29, 2007 | 04:45 PM
White_Hawk's Avatar
Find your length checker. It sounds like you are short. I milled my heads 0.030" and I still needed 7.425" pushrods. Every build is going to be a little different, though.
-Geoff
Old Nov 29, 2007 | 06:51 PM
qwikz28's Avatar
-Geoff
no dice, i looked everywhere for it. even if i had it, i wouldn't know how to use it nor have the time. i'll probably just have the shop thats fixing my rear check the length too.
Old Nov 29, 2007 | 09:36 PM
tkimrey's Avatar
I'm not sure if this helps you any but I dynoed mine tonight and put down 355rwhp and 320 rwt with mods in my sig....
Old Nov 29, 2007 | 11:10 PM
SweeTbone's Avatar
Something is wrong for sure. +1 for ^ there too tkimrey. FWIW, I used 7.425 pushrods on my unmilled heads and a stock GM gasket and stock rockers.
Old Nov 30, 2007 | 09:40 AM
tkimrey's Avatar
I was thinking the same thing, but I think it may have been the dyno I was on. The guy that tuned it sayed he only put down 358 in his H/C SS but he still runs 11.80's.
Old Nov 30, 2007 | 09:43 AM
qwikz28's Avatar
i would get it retuned then. how does it feel, and who did the install?
thats interesting cause i have just regular 7.400 pushrods. i wonder if there is a difference between the two different heads we have.
Old Dec 1, 2007 | 07:01 PM
tkimrey's Avatar
Feels good, I can feel the difference for sure. Glen from Powerhouse Performance tuned it.
