All bore 383ci vic jr numbers!!
1 Post
If I get close to those numbers with my 408 I would f...n sh.. a brick!!! That is awesome.
On another note...where will the 4.30's put you crossing the traps because you will windout each gear faster. I am conservative, I guess, but I would do some 3.90's and get a 4400 stall if I were you. Just my $0.02
Cam specs...LOL
It's in the 240's @.050 & has over 20 degrees of overlap. Not really that big, but not exactly smogable either.
If this was a dedicated drag setup it'd have 4.56's.
With the lockup in 3rd gear 4.30's @135mph will put it at 6800RPM using a 28" slick (growing to 28.5" on the top end).
4.56's would be 7250RPM.
Yes those are good numbers. Its a race motor 12.5:1 on race gas, so I dont see why people are expecting or comparing to see those numbers out of a street motor though. Thats a nasty motor though, pretty sick!
Whats your race weight?
Can you or can't you fit a air filter? I need one to fit mine somehow.
I am doing a 408 AFR 225s 62cc 12-1 Vic or Super vic(if its out) with the Accufab TB and I'm hoping to make 500RWHP.
Ive never tried to fit a filter on, but im sure u can find something to rig on there. Ive had to cut out the whole cowl to get some room, but it would be pretty hard if I didnt cut anything out. Basically impossible to fit a filter if u dont cut the cowl.
raceweight was 3510 last time i checked.
On pump gas with 11.4:1 comp it made 512hp.....with a vacuum leak I found later. Went 10.56 @131 then. I even drove it on the street for a bit, so it wasnt a slouch on shell 91 octane either
#32
The intake was 420$ (i think) from Summit. Somewhere in the 400 dollar range. I just did alittle smoothing and some basic port matching to the ETP's. Maybe 2-3 hours of work. This intake definalty like the higher RPM's over a fast or LSx style intake. The graph shows it over 500hp from 5800 to 7000 RPM.
#35
Not bad at all actually. I could drive it like a cam stab car all day, but the cops and laws here in CA are alittle harsh so I would get paranoid. The cage and harness are visible and every time I saw a cop I would freak out and dart down a side street. Not worth it, so I made it a trailer queen.
gas mileage wasnt that bad either, but who cares about gas mileage when u have 500hp?? If u care about that, then u should leave it stock
#36
1 Post
[QUOTE=NosboySS;8390096]Not bad at all actually. I could drive it like a cam stab car all day, but the cops and laws here in CA are alittle harsh so I would get paranoid. The cage and harness are visible and every time I saw a cop I would freak out and dart down a side street. Not worth it, so I made it a trailer queen.
+1 Here for darting down a side street every time i see the FUZZ!
They are no joke around here.Btw. nice #'s
#38
[QUOTE=SincalT/A;8390134][QUOTE=NosboySS;8390096]Not bad at all actually. I could drive it like a cam stab car all day, but the cops and laws here in CA are alittle harsh so I would get paranoid. The cage and harness are visible and every time I saw a cop I would freak out and dart down a side street. Not worth it, so I made it a trailer queen.
Thats why I went turbo even bigger power and full stealth capability. My ride is just as quiet as stock with the cutout closed.
#40
Great set up! I getting ready to drop my 383 short block off at M&M machine for final balancing and getting checked out before we assemble it. It's an eagle rotating assembly and 97 machined ls1 block I got earlier this year. I'm putting it together with my afr 205's and Vic Jr intake, 750 demon carb, and T rex cam. it will be going through a coan th400 with a brake and a tcs4500 vert. I have no idea what to expect but I hope it does 500+rwhp.
This will be in my 93 mustang coupe. I hope the race weight will be around 2800#. I'm shooting for low 10's on the motor. And the following year I'm going to put a edelbrock plate system on it. Gunning for low 9's.
I like the short stroke big bore motors for making fast rpm's. But mine is the 3.905 bore, 4.00 stroke, 6.125 rods.
I will be having mike duke port the intake and massage the heads open a little bit. He his a very reputable head porter around here.
