ETP tweaked L92s/ 06 GTO
Heres an interesting L92 case.The car is an 06 GTO. Now mind you, this thing didnt have an "optimal" L92 cam. Heads were redone by ETP. No additional port work, just milling, tighten up the springs, back cut valves, 5 angle valve job, and seats blended into the bowls.
In addition to this, I decided to try one of Corys intakes (ls2PortWorks).
I was hoping for 20 from the heads (I knew that was a pretty much a given) and another 10 from the intake (thats what Cory told me to expect)
So, anyways, heres the results........
Run 12 is what it was with a good street tune in it.
Run 15 is maxed out tune. Now that run (15) is with a crazy amount of timing in it, and pretty lean at the same time. It turns out that it liked a bunch of timing because the compression was really low.
Run 17 is THE REDONE HEADS ONLY with 6 degrees LESS timing, because of the compression.
Run 20 was same as run17, just a higher tq number.
Run 22 is AFTER SWAPPING INTAKES. Needless to say I was VERY impressed with the gains from the intake. It gained the 10 HP that Cory told me it would, but LOOK AT THE TORQUE!! Thats a good 18-20 ft lbs with just the intake swap!!
To sum up, the L92s have some issues that are just part of their design. For the most part, they CANNOT be bolted right on and make the power that they should make.
That being said, these heads had some issues that they just shouldnt have had. Attention to detail, and just plain 'ol 'sperience got this combo to where it should be.
Thanks to ETP, and to Cory at ls2PortWorks (no link, non sponsor)
LS1 Tech Administrator
Great writeup Ed. Backs up what the rest of us have been seeing too...the L92 can be fine heads with the right intake manifold in front of them. The L76 manifold is not very good in stock form. It would be interesting to know the areas that Cory attacks with the porting. Regardless, those are solid numbers! Well done.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I've done enough of the L92s to know what to expect. If you are getting a legit 500+ out of a 6.0, you should be selling those combos left and right.
BTW, has that thing been run on a DJ yet?
Nice work Ed. So I would expect with the changes I've made on my car and the addition of the YT rockers and Cory's intake I should be north of 530/500 on my baby cam "Gentleman's Cruiser". Let me take care of the Tiger Shark stuff and I'll come done. Probably about 3 weeks.
TQ looks good from 3000 on...
I like the fact that it peaks about 6200 too...
I like that u did tweek these heads,most people think u just bolt them on a go.This is NOT the case,with alittle bowl work,good valvejob and some exhaust work the L92's really make for a nice setup..
Would be interesting to see how the ET 243's do at $1300 a set vs their modded (how much do these ET L92's cost) L92's .It would just be interesting to me to see a ported LS2 intake and a set of 243's vs this setup...
Wonder which would cost more in the long run?
We've used the 243s from ETP. They would be a nice comparison to these.
I was more impressed with the gains from the intake. I expected the heads to pick up what they did.
Hey Ed, am I seeing this corrrectly? The L92's are pulling cleanly past 6500? It's too bad you can't slap these on a certain 347-that would be on happy camper! Now that I think of it-that would a test for these L92's with no intake as a restriction!
OWN3D BY MY PROF!
I'd also be interested in some rough cam specs if you don't feal like divulging the whole schmeel. I noticed that they pulled pretty well up top too. I might just pick up a set of L92 castings to mess around with. I've got a few ideas I've been thinking about doing with them.
