Budget 6.0 Build
Stock '05 LQ4
Edelbrock Victor Jr
650 Double Pumper
1 3/4" long tubes, 3" collectors, 2.5" xpipe
All of this will be backed by a Fuddle 3600 stall, built 2004r, 4.10 gears, and 26" Hoosier. Car should weigh in a little under 3500lbs with driver.
After I get the motor in and running, I plan to do a cam/spring swap, looking at a few different grinds, some where in the upper 220 duration and around 0.585 lift.
Any one have any input? Suggestions? Power ideas? I'm hoping the setup without a cam swap should get me into the 12.40s-12.60s and the cam swap should get me into the high 11s.
Thanks guys
Nick
with regard to fuddle converters - i had one and loved it. i had a problem when i first got it, but they stood behind it and took care of me, no problem. because of this i am buying another one, but it will be a little bigger.
My LQ4 went 12.83 @ 107mph in 2000' DA (race weight of 3725lbs), while dynoing 342rwhp unlocked. Now with the F13, it is at 390 rwhp with the converter unlocked. Next week I shall see what it traps, ET (on street tires) should be in the low 12s.
I'm also leaning towards a yank SS3600, thats if they can make it for my 2004r with an LS1 pilot (or if not, I can run the Hughes adapter).
The F13 with a 112lsa looks real good. 12secSS, what springs did you run? Let me know how your car runs.
Thanks
Nick
