PRC 5.3's and MS3 with PT4000
Old Feb 8, 2008 | 01:06 PM
XS HP's Avatar
Default PRC 5.3's and MS3 with PT4000
Well, got the car tuned last night and it put down some good #'s. Heres a mod rundown:
PRC Stage 2.5 5.3 head
MS3 cam 112lsa
LS6 intake
Underdrive pulley
4.11 gears
Pt4000 converter with 2.6 str
The runs were all UNLOCKED and it put down 417rwhp 382 rwtq . The bad part was that on the way home the car would no longer shift into 3rd. So the stock tranny is done. I knew it would happen soon but I was hoping to get a few runs out of it al least. Th400 time I guess.
Old Feb 8, 2008 | 02:20 PM
blu1's Avatar
MS3 cam 112lsa
LS6 intake
Underdrive pulley
4.11 gears
The runs were all UNLOCKED and it put down 417rwhp 362 rwtq . The bad part was that on the way home the car would no longer shift into 3rd. So the stock tranny is done. I knew it would happen soon but I was hoping to get a few runs out of it al least. Th400 time I guess.
Nice numbers but are you sure that MS3 is on a 112 and not a 113 with those heads?
Old Feb 8, 2008 | 02:31 PM
XS HP's Avatar
yeah, its 112 and clears ok
Old Feb 8, 2008 | 02:34 PM
88GT&69ss's Avatar
should be pretty sweet!
Old Feb 8, 2008 | 05:31 PM
andy670ho's Avatar
That is very similar to my run, I have the same heads, cam, intake, no underdrive pulley, 3.73 gears and 3800 stall and I put down 410/370. Have you had it to the track yet? I am running a 150 shot with drag radials and stock suspension and went 10.84 with a 1.49 60 ft. You will like that cam at the track, your stall seems quite a bit better than mine you should put up good times, My str is only 1.69 so I needed the juice to get off the line, Let us know when you get some times!
Old Feb 8, 2008 | 08:32 PM
chrs1313's Avatar
Your really gonna like that combo.My dad has the same combo except he is running pt4400 and fast 90/90.His car runs in the mid 10s
Old Feb 8, 2008 | 09:06 PM
Loadre's Avatar
What kind of exhaust on all these cars?
Old Feb 8, 2008 | 10:46 PM
venom ws7's Avatar
Congrats those are great numbers with Unlocked.
Ported Fast 90/90 setup will work awesome on that car.
Old Feb 9, 2008 | 09:52 AM
XS HP's Avatar
Yeah, right now im just rying to get the tranny issue resolved- but i am certainly looking forward to running it soon. BTW- it put down 380 tq not 360, I had a little typo! The car also has a custom true dual set-up dumped before the axle.
Old Feb 9, 2008 | 05:22 PM
cals400ex's Avatar
don't the standard pt4000's come with a little less str than that?
Old Feb 10, 2008 | 11:08 AM
FoolZRacing's Avatar
nice #s. Get some track times now
Old Feb 11, 2008 | 07:42 AM
PewterScreaminMach's Avatar
Nice numbers! Those MS3s are great track cams from what I hear and with your gears and converter, you're gonna run some impressive times with a decent set of tires.
Old Feb 11, 2008 | 08:37 AM
LT1BRN's Avatar
Nice numbers, makes me wana go LSX
Old Feb 11, 2008 | 06:22 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Great results bro, sorry to hear the tranny died
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
