anyone ever run TFS 235's on a 370?
jeff you should really look into the TFS 225 for a 370. i think you would see just about the same results, cause the TFS 235 are really for a minimum 4.10 bore if i am not mistaken. but with a 6 speed, i would see it putting between 460-480 at the wheels, maybe even close to 500.
I have a customer by the name of Xessive in TX that had a customer bring in a truck with a 6.0 engine in it and they had installed TFS 235's and it actually made 500 RWHP, which shocked me, but the TFS 235 intake port only measures 230-231cc.
We've had a LS2 Corvette make 507 RWHP with the TFS 225's, and I just had a guy in Canada with a LS 2 Corvette make over 500 RWHP with the TFS 215's.
So I would say if you are planning on nitrous, use the TFS 235's, they are wicked on the spray. I have a customer with a 402, TFS 235's, our 250/266 N2O cam, Fast 90/90, pump gas engine (on race gas of course) run 8.80's in the quarter mile at 3500 lbs on 2 stages, he was happy.
i got them from a buddy at a great price so the are already on the motor & in the car
the only differences will be, the heads/rockers & bullets off the headers vs. choking y-pipe and the patriot heads. it did 480/435 before & ran 7.30 @ 97mph 1/8th (3700lb raceweight, 3.89 gear). its lost 100lbs & has 4.30's in it so i'm hoping for some 6's & 10's in the qtr.
well i got it running and got the WOT tuning partially done. went to the track yesterday for some runs. slowest run was a 6.93 1/8th best run & mph were on the same pass. 6 speed (all motor) skreet car weighing 3600lbs.
1.499 60'
6.788 1/8th et
103.18 mph
so they seem to work decently
1.499 60'
6.788 1/8th et
103.18 mph
370 iron block, 11.75:1 c/r
248*/254* .610/.619 110.9 lsa cam
TFS 235's milled to 62cc
morel lifters, jesel rockers
fast 90 i ported
pacesetter headers, bullets
open loop SD tune by xXx motorsports (before with PP heads, i tweaked the WOT fuel.... retune to come soon)
faceplated t56 i built
spec 5 billet steel fly
midwest chassis fab 9" backbraced 35splines & spool, 4.29 gears, tranny crossmember mounted midwest torque arm
mt 28*10.5*15 drags
qa1's rear, stockers front. bmr k-member
3625lbs race weight
fast 90 i ported
mt 28*10.5*15 drags
3625lbs race weight
I have a 370 with 225s on it with a 242/256 on a 133lsa, raceweight of 3480 first pass with the combo went 10.82 at 124 which impressed me since it is a nitrous motor and the car has NOS converter 28" slicks with 3.73s. Talking about a mismatched combo and it it still runs a number.
TEA has got my vote Ive bought numerous sets of heads from them and all of them turn good numbers
