how much power ls6 heads?
FWIW, I have a set of 243's with fairly extensive porting and "street car" valvetrain parts (SS 2.055/1.60 valves) that did around 535/500 RW on a 11.8:1 hyd 408". Same heads did around 470 RW on a iron 370" with alot less compression.
They flowed around 325/225 on a 4" fixture if I remeber right with great mid lift #'s too. I'd offer to sell them to you, but the chambers are sized for a 4.030" bore.
I learned one thing you have to watch out for is that some head providers grind so much out of the intake ports that small holes are present. Although very difficult to see, they allow oil to be sucked into the combustion process. ET Heads have their own casting, so this danger is avoided.
