What to expect Heads & cam Combo
Old Feb 20, 2008 | 03:46 PM
O6DODGE's Avatar
Default What to expect Heads & cam Combo
I am going to put a set of Gm casting ls6 ported heads on with the mti r1 cam, what can I expect. The heads are supposed to be hand ported to were the ports are with in 2% of each other. This set up will be going on a 99 C5.
Mods Include:
1:Lg Long Tubes
2:Haltech Venom Intake
3:Ls6 Intake Manifold
4:Lg Off-Road X
5:Borla Stinger catback
I would like to know what your oppinion is on the setup and how much power do you think it will make. I also have a Nx twin nozzle setup pilled to a 150 shot. Let me know what you think
Thanks
Adam
Old Feb 25, 2008 | 10:33 AM
s10-den's Avatar
I have those very heads and the hot cam going into a s10 with 6 speed....in a mag i have it made 510hp on a stock bottom end ls1 with the cnc ported gm heads and cam with 1 3/4 headers,on motor with no acc.
Old Feb 27, 2008 | 06:30 AM
Rameaux's Avatar
Default H/c
For a reference I made around 430 with a 233/239 cam with PRC 2.5 LS6 Heads and a goos set of LT's. Tuned of course. I'm not familar with the specs fo that cam so I couldn't give a great guess.
Old Feb 27, 2008 | 07:26 AM
Tom's_03SVT's Avatar
what are the specs on that cam?
Old Feb 27, 2008 | 12:22 PM
marcus769's Avatar
I have a pretty stout Heads/cam setup in my car... Let me start by saying it makes great power, but the driveability is somewhat sacrificed by the low rpm surging, which i'm sure you've read about if you've done any kind of research about head/cam cars. I have the Futral F15 cam (look at their site for specs). I think you'll be somewhere close to my power, so i'm sure your drveability will be similar. Thats the only thing i do not like about the car.. Its great fun, but the surging sometimes makes you look like its your first day on the clutch! LOL!
Old Feb 27, 2008 | 03:11 PM
96lt1ss's Avatar
420-435ish
Old Feb 27, 2008 | 06:20 PM
O6DODGE's Avatar
The specs on the cam are 232/236 .575/.578 on 112lsa
Old Feb 27, 2008 | 06:22 PM
O6DODGE's Avatar
What heads did you use? Yeah the surging wont be a problem the cars not dd, so I will only have to put up with it on the weekends. Pm me if you dont wont everyone else to know.
Old Feb 28, 2008 | 07:22 AM
Old Feb 28, 2008 | 07:47 AM
matthewjernigan's Avatar
sorry off topic but is that your vette? god i love those CCW's on that white
Old Feb 28, 2008 | 08:05 AM
BlackScreaminMachine's Avatar
Internet Mechanic
It will make good power
Old Feb 28, 2008 | 08:19 AM
allngn_c5's Avatar
I have virtually no surging or bucking in my setup. Occasionallly she will stutter a bit (after running WOT on the EWAY and coming into traffic) as if it were about to stall, but recovers nicely. Good tuning goes a long way.
Old Feb 28, 2008 | 08:30 AM
7420NW7TH's Avatar
Sounds like a stout setup
Old Feb 28, 2008 | 09:19 AM
O6DODGE's Avatar
Are your dyno #'s in your sig just head/cam?
Old Feb 28, 2008 | 10:44 AM
allngn_c5's Avatar
My Setup 346 ci LS1 11.5 to 1 compression
Afr 205cc heads milled to 59cc, G5X3vII cam, Ported 90 mm FAST, Ported 90 mm Nick Williams T/b, ASP u/d pully, Meziere EWP, LG Pro Longtube headers, BBexhaust Catback system (no cats, or mufflers on this setup), .040 cometic headgaskets. I think that about does it. Exedy twin plate clutch, carbon fiber drive shaft, DTE stg III rear end with 3.42 gearing.
Old Feb 28, 2008 | 12:37 PM
O6DODGE's Avatar
Damn thats a badass setup. How did you race the compression, just by milling the heads or did you build the motor that way?
