AFR 225 Vs L92 Top end on 416 Stroker... Results Inside!!!
#44
Thanx guys... Ill be posting updated results on the AFR setup in a day or so. We put the GTO back on the dyno Friday evening for some small tweaks and melted the OZ700 disc to the flywheel. Seems it has been slipping a bit and finally let go. Breaking in the new clutch now and will get it back on the roller sometime this week.
As for the AFRs, they are out of the box heads as anyone would get them. As far as I know Tony did nothing special to them.
Stay tuned....
Stay tuned....
#49
Moderator
Great numbers but I really would love to see the FAST swapped for an LS6 (similar match for the L76) intake to compare the heads a bit closer. The biggest problem is the intake on the L92's. Im confident with a FAST ported L92 intake they would be much much closer. How long does it take to make an aftermarket L92 intake for Gods sake?
#51
Well you can also take into caparison the price diference between the two. Also if somebody decides to make an intake that is comparable to the fast for the L92 heads it would be a different story in my oppinion. That l76 intake cant push half the air that the fast can and falls dead before 6500.
