final heads/cam #'s
Here is my setup.
2002 Z28 Camaro A4 with Trickflow 215cc heads milled to 62cc, Harland sharp LS1 shaft roller rockers 1.7 ratio, 232/236-642/612-114LSA cam, FMS chrome-moly hardened 5/16" push rods 7.500", ARP hex head bolts, FMS ported oil pump, LS6-2 timing chain, 30lb SVO injectors, SLP 85mm MAF, all free mods, Hooker longtube headers and y-pipe, Magnaflow catback, PTC 3600 Stall converter and dyno tuned by Allan futral.
My buddy has a 2001 formula A4 with pretty much the same setup but he has the dart heads and his made 438rwhp with the stock converter.
I think the tranny might be slipping a little, so that would explain the lower power #'s. Please let me know what you guys think. I live at sea level in New Orleans LA.
You should be in the mid to low 11s with some sticky tires.
(If your stall & trans performs well) Trending Topics
Jon
