408 just dynoed :)
Old Apr 7, 2008 | 09:19 PM
98mysticZ's Avatar
Default 408 just dynoed :)
well i just got my dyno run done but it needs another tune..... saw somethings he didnt like just didnt have time to change them..... was at closing time
so here is the break down on the build
iron 408
eagle crank
eagle rods
diamond pistons -2cc
diamond rings
durabond cam bearings
clevite main and rods
shimmed 6.0 oil pump
ls2 chain
texas giant
gm mls headgaskets
ported 317's told flowed over 300cfm @.600 but dont have a sheet on them
prc dual springs w/ tit retainers
caddy lifters
7.4 push rods
h/s roller rockers
tr6 plugs
taylor wires
ls6 intake
prof prod 80mm throttle body (ported)
fasttoys 85mm lid
ls6 maf
ss autochrome headers 1-7/8 if i remember right
tsp true duals
exedy hypersingle
3.73's and 17X11's zr1s
and a shaun burt tune
so 484/462
stangkiller2005's Avatar
can i drive it?
Old Apr 7, 2008 | 09:23 PM
Gordon0652's Avatar
A4 or M6?
Old Apr 7, 2008 | 09:37 PM
98mysticZ's Avatar
m6 and no
Old Apr 7, 2008 | 09:43 PM
allngn_c5's Avatar
Not to shabby, but that 408 is screaming I can't breath !! Get her a 92 fast ported by Ron at Vengeance, or Tony Mamo at AFR with a matching T.b. You would see another 25 rwhp easy.
On a side note what did you tuner see that he didn't like? Was it your rich air fuel ratio. She's a good bit rich. You know after you get your A/F fixed, you will probably see a good bit more power from that as well. Good luck and repost after she's fixed.
Old Apr 7, 2008 | 10:04 PM
98mysticZ's Avatar
yea i know i need an intake just couldnt payfor it right now... time to save haha i like the numbers i got and once the a.f gets fixed i figure it will be right where i want it for now lol..... key word now lol
Old Apr 7, 2008 | 10:48 PM
raptorws6's Avatar
Very nice #'s.
Old Apr 7, 2008 | 11:04 PM
ExceSSive's Avatar
Very nice considering the AF ratio...get it re tuned and report back...and I agree with a 92/92 you could pick up some more power.
Old Apr 7, 2008 | 11:06 PM
98mysticZ's Avatar
will do hope i can get it retuned before the 27th and i can get it dynoed again at a big car show
Old Apr 7, 2008 | 11:11 PM
allngn_c5's Avatar
Just don't forget the PM I sent ya RE:your intake/tb She's coming off may 12th
Old Apr 8, 2008 | 08:13 AM
venom ws7's Avatar
Nice numbers man Congrats with Ported 92 setup and retune 500 for sure.
Keep us posted man and good luck.
Old Apr 8, 2008 | 08:42 AM
gtodoug's Avatar
Incredible numbers considering it's new motor, using stock castings that were ported, no fast, stock wp, no 90mm tb, running through a 3.73 gear and, and heavy *** wheels.
Old Apr 8, 2008 | 02:01 PM
mike c.'s Avatar
Great #'s for an ls6 intake. You will see over 500hp with a ported fast on that bitch. No boubt you have a beast on your hands and the fast will wake it up. CONGRATS TO YA.
Old Apr 8, 2008 | 02:35 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Nice results! I agree, the FAST/PTM 92/92 should pick you up close to 20rwhp!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 8, 2008 | 08:19 PM
camarokid94's Avatar
nice results nailin down that AF ratio should get ya 20 in the middle the way it looks
Old Apr 9, 2008 | 01:07 AM
smok'nZ's Avatar
MASS seller approved
bring it to oklahoma and have an ed write tune put on it
Old Jun 4, 2008 | 04:48 PM
CBIII's Avatar
are those heads milled? youre giving up a decent amount of power from the loss of compression with them
