340 rwhp with PRC 2.5 heads, 234/238, fast 92/92 etc. Trying to find the problem
Hmmm im a ls1 guy that has done about 50 heads/cam setups on ls1 cars, tuned a few hundred cars and dealt with about every problem ive read about but I cant seem to find the missing horsepower in this setup
It dynos 342 rwhp locked converter with the following:
PRC 5.3 Stg 2.5 heads milled to 59cc
234/238 @ 111 custom camshaft
fast 92/92
stock 10 bolt with 4.11
locked converter 4l60e
7.4 pushrods
prc double gold valvesprings
obx longtubes with true duals
timing at 28 degrees no knock retard, 13.0-13.2 a/f everywhere.
The car runs well but back to back on the dyno puts down 80 less rwhp than another car with the similar setup with a smaller cam on same dyno, same day.
Any ideas? I figure ill run a compression check on the 80k mile motor first....but after that I cant find a thing wrong with it.
fast 92/92
7.4 pushrods
I would do a leak down instead of a compression test. Did you log the trans slip counts during a run to make sure the TCC was not slipping under a WOT Pull? The TCC could just be junk.
I hope you figure it out...I have those same heads and ported fast 90/90 and my cam is almost exact 232/238 6xx 6xx 111lsa+2 and a A4 too,and put down 435rwhp 407rwt..Hopefully this gives you an idea where you should be..Good luck I hope you fin d the problem
