20rwhp 26rwtq gains from PatG/ Vengeance Intake/Tb/ TSP 1.7/8 and manual Trans (HELP)
Old 07-13-2008, 09:00 AM
venom ws7's Avatar
Unhappy 20rwhp 26rwtq gains from PatG/ Vengeance Intake/Tb/ TSP 1.7/8 and manual Trans (HELP)
Here is the before mods and numbers:
Car is 01 LuminaSS A4 (Sedan GTO Here in Middel East)
6.0 LQ9 Iron Block Bored .030
Eagle Crankshaft.
Diamond Piston -10cc.
Scat Connectting Rods.
Clevite Main & Rod bearing.
TSP Ported Oil pump.
TR Trex 242/248 611 620 110lsa with all valvetrain.
PRC LS6 Stg 2.5 Heads Milled to 62cc
Compresstion is around 11:1
Stock A4 two peice driveshaft.
stock stall & gears.
Sureflow headers (very small)
2.5 ORX into 2.5 Magnaflow.
Stock TB.
LS6 Intake
K & N Filter
ASP Pulley.
Stock MAF
stock water pump.
Tuned by HP Tuner.
best numbers were 445rwhp 430rwtq which I thought they were good for the mods and trans.
Here is the graph
After that he sold the engine to his friend his car is 01 Z28 M6.
Here is the after mods and numbers:
PatG Custom cam. (this was for A4 Lumina I talked to Pat before the owner sold the engine) I'll post the specs when Patrick see this.
Vengeance Racing ported 92 intake (awesome work) Thanks Ron.
FAST 92mm TB.
TSP 1.7/8 Headers (awesome headers) Thanks Trevor.
OR 3inch X-pipe with Magnaflow Mufflers
Stock M6 Trans with SPEC stg5 Clutch with Alaminum flywheel.
Stock shaft with stock rear and gears 3.42
Tuned by the same LuminaSS Tuner.
with these mods the Goal was 490+rwhp 460+rwtq
Here is the numbers
ALL COMMENTS ARE WELCOME I dont have much expreince (spelling) but I think its the tune.
Thanks in advance.
Old 07-13-2008, 09:48 AM
LS1 Tech Administrator
Patrick G's Avatar
You certainly gained a bunch of power in the low and mid-range. You'll have to refresh my memory of the cam specs. I only have cams listed by the user's name and not internet screen name.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 07-13-2008, 09:55 AM
MASS seller approved
smok'nZ's Avatar
those m6 numbers do seem low but maybe you need some new heads but since you have a vengence 92 they will open the tb snout too 100mm for not too much$ you could sell your tb to get the new 100mm that will defently pick up some power
Old 07-13-2008, 10:16 AM
venom ws7's Avatar
244/258 621/595 113LSA +4 advance
Old 07-13-2008, 10:19 AM
venom ws7's Avatar
The car is sick in the low and mid range the customer love it but I thought the peak power will a little more.
Old 07-13-2008, 07:20 PM
Ryan L's Avatar
Why does your a/f ratio look like a roller coaster? I wouldn't doubt if you were getting some detonation since you are tapping 14:1 at some points.
Old 07-13-2008, 07:39 PM
1989GTA's Avatar
I agree on the posible detonation. Maybe some timing is being pulled out.
Old 07-13-2008, 09:06 PM
myfast70's Avatar
The air temp was a bit higher in the second graph (almost 16* F)
Old 07-14-2008, 06:49 AM
venom ws7's Avatar
LOOOOOOOL I swear man thats the same thing I told the tuner roller coaster I dont know much about tunning but the A/F looks like crap.
This is not my car I just order parts from U.S to overseas
He pulled two degres if I remember correctly.
Thats right the wheather was hot as hell (overseas)
Oh the car had only 80miles I talked to the owner last night and he said the car feels a lot stronger after the 300miles so we are taking the car back to the dyno in the next two weeks to see the new N/A numbers and Nitrous numbers
Old 07-14-2008, 06:54 AM
venom ws7's Avatar
But I need more help and advice what should I do next time on the dyno????
Timing??? A/F??? best shift point????
One last thing Patrick the car SOUNDS SICK and pulls hard all the way past 6600rpm.
Old 07-14-2008, 07:15 AM
LSWONGTO's Avatar
You could try to talk to jerry formato. He is one of the best LSX tuners out there from what I have read and you could talk to vengeance because everycar they tune leaves with a happy customer and good #s.
Old 07-14-2008, 07:58 AM
venom ws7's Avatar
Believe me if it was easy to let one of these guys to tune the car I would call them ASAP.
But the car is Overseas the wheather , Fule is very diffrent.
Old 07-14-2008, 10:49 AM
White_Hawk's Avatar
I don't see a whole lot of changes that could account for a big horespower jump that you seem to be looking for. It is hard to comparre A4 to M6 numbers anyways. If it feels strong, then go with it. There is probably nothing wrong with it. Most of the setups making 500 have AFR, TFS or ETP heads.
-Geoff
Old 07-14-2008, 11:52 AM
edcmat-l1's Avatar
Whats the engine size? I see it has an Eagle crank, but is it a 403 now?
First thing I would do is make sure its hittin on all 8, then get the A/F in line, then hope for the best.
Old 07-14-2008, 12:27 PM
LSWONGTO's Avatar
Yeah thats true but you can always ask for a little advice from them, its always worth a shot and good luck bro. Since im in kuwait right now do you know when the sandstorms start? I ask because today was windy but not like a real sandstorm well good luck bro.
Old 07-14-2008, 12:45 PM
brad8266's Avatar
That power change isnt very suprising, you picked up 26 peak but also picked up a good amount throughout the range. The cam change was not drastic either. How you expected to pick up like 50HP from a minor cam change and intake I dont know.
Old 07-14-2008, 03:37 PM
1ORANGEWS6's Avatar
He changed more than just the cam. A better intake and bigger headers. I'm not and engine expert but I would have thought it would have picked up more than what it did and going to an M6 from an A4 tranny as well.
Old 07-14-2008, 06:30 PM
edcmat-l1's Avatar
It will only pick up that kind of HP and tq if there was something wrong with the setup. If it was deficient in some way.
Going from an A4 to an M6, if you're running the A4 locked, makes little difference.
Now, back to my original question, is it a 403? If it is, its pretty weak. Before or after the latest mods.
Now, if the compressions off, if theres a bottleneck thats causing a restriction at higher rpms, then theres your reason. Theres ways of diagnosing these problems too, but it needs to be in the hands of someone with that capability.
Old 07-14-2008, 06:56 PM
OUTLAWZ RACING's Avatar
Heads? put some TFS or AFR
Old 07-14-2008, 07:07 PM
venom ws7's Avatar
Its either 402ci or 408ci I'm really not sure.
Thanks for the advice man I'll let you know the new numbers.
Better and bigger cam.
from stock LS6 Intake and stock TB to PORTED 92mm FAST Intake/ 92mm TB.
crappy headers to 1 7/8 Headers with 3inch off road X-pipe.
Manual transmisstion and one piece shaft and light aluminum flywheel
all these mods only get 20rwhp peak power is low IMO
Thanks for the replies guys.
