what will it run in the 1/4 mile???
i was wondering what my 95 z28 lt1 a4 would run having slp cold air intake, msd coil, mac cat back exhaust, ported throttle body, air foil, and aluminum drive shaft, with Goodyear street tires and everything else stock 72k miles
i was hoping to get below 14.0
if you dont think i can get it below 14 what other mods (relatively cheap) could i do to get it into the 13s
i have not run the car yet so i'm trying to get an idea of what it will run
thanks
thanks
^x2 what gears? and i'd say with DR's you should be able to pull a high 13.
with your mods plus long tubes thru a chokemaster with a tiny lil baby cam i pulled off a 13.3 in around 2000' DA.
yes that is a nice time!! Wat was your 60ft time? did you launch it easy and then put 100% throttle? I ask because i plan on going to the track with my goodyears to
the 60ft was 2.019 at 81.19 mph and that was easing into it.
i could not have stomped on it out the gate, i would of spun
i never would have thought it would have run that time pretty much stock
the first pass was 13.73 at 101.13
the second was 13.622 at 101.58
the third was 13.633 at 101.41
all 60's were 2.0 at 81 mph
