Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
future mods
Old 04-29-2009 | 01:13 PM
mattgt40's Avatar
Default future mods
if i put all the mods listed below what would my HP & E.T be
current mods
Flowmaster cat-back
cat delete
QTP Electric Cutout
K&N cold air intake
BBK TB
Nitto D/R
Shift kit
3:73 gears
future mods
LT4 hot cam hit
LT1 Platinum PRO1 Heads 180cc/58cc
sub frame connectors
sway bar kit
pan hardbar
lower control arms
Old 04-29-2009 | 04:07 PM
PNYKLR-TA's Avatar
Why hot cam kit? i'd personally scratch that all together.
and if you did all that with a better cam, i'd say HP would be around 350-380 at the rear wheels, of coarse depending on cam like i said.
1/4 Mile time anywhere from 12.5-13.00. Really depends. Also if you are gunna do that, i'd throw in an aftermarket stall converter with a higher stall speed than stock. That will drop you nearly .5 in the 1/4 mile.
Old 04-29-2009 | 04:10 PM
AznMuscle's Avatar
Ben, don't you have a hotcam
Old 04-29-2009 | 04:11 PM
Sarge_13's Avatar
15's. It is an automatic LT1 after all...
Old 04-29-2009 | 04:19 PM
AznMuscle's Avatar
LOLOL. Sad thing is...that is what they run here.
Old 04-29-2009 | 04:31 PM
PNYKLR-TA's Avatar
NO! i have a Speed Inc Custom Grind EH! The Cadillac Cam
thanks jerk! i ran a 14.0 stock auto haha with only 3.23 gears too
and LS1's run 14's so that doesnt make it all that bad
Old 04-29-2009 | 05:10 PM
AznMuscle's Avatar
1) WTF is a cadillac cam. Specs, n00b.
2) No, MY ls1 runs 14s here....better drivers run high 13s . ***.
Old 04-29-2009 | 05:16 PM
PNYKLR-TA's Avatar
You're a dickweed kyle haha! better drivers run high 13's
and specs are as follows, 212-219 .530 .540 lift.
Those lift numbers are on stock 1.5RR's as well. So with the 1.6's i have its .565 and .576
really high lift, not so much duration wise, so it is similiar to a hot cam you 'could' say, its got less duration, but more lift. 113 LSA
Old 04-29-2009 | 06:36 PM
AznMuscle's Avatar
Stop dicking around, and do a ******* 240s cam. You are going to need it.....
Old 04-29-2009 | 06:57 PM
greatskiiiier's Avatar
why dont you both STFU and start modding so you can play with the BIG BOYS
lmao- funny part of that is some guy said the "big boys" part to me when i was trying to get my wheels to stop rubbing (12 bolt swap)
anyways- ditch that cam and give Lloyd Elliot a call (sorry if hes not a sponsor here)- youll def be low 12s if now high 11s then
Old 04-29-2009 | 07:01 PM
AznMuscle's Avatar
I'm having Ed Curtis spec my cam..I got heads sitting in my garage. Trust me, I will be able to run with the teenagers . Big Boys run 9's....I need my 200 shot and 9 inch first.
Old 04-29-2009 | 10:05 PM
lmao- i consider Big Boys anything under 15.0, judging by the guy that said it to me lmaoo
Old 04-30-2009 | 12:29 AM
AznMuscle's Avatar
HAHAHAAHAHA! That sucks dude...don't you hate ignorant people?
Old 04-30-2009 | 11:03 AM
PNYKLR-TA's Avatar
HA! ok boss i've got a pretty decently high DA to deal with.
And the cam will most likely be changed when i get my new heads, and rebuild. . . but we will just have to see.
OP where'd you go?
Quick Reply: future mods
