How much can i land?
Hi guys sorry i knw this is an LS1 site but i have a 94 Trans Am full wieght reduction, 355ci stock bottom end LT1, Lunati VooDoo 294/302 Camshaft kit with the springs and everything 2.00/1.55 oversize valves handported intake manifold and heads to gasket size, NGK V-Power plugs, MSD wires, 4l60e Tranny with TranSGo Reprogamming kit, HD Borgwarner Clutches, HD pistons, stock 10 bolt diff with GM 3.42 ratio, M/T drag radials how many seconds do guys think i can land in the quarter mile without Nos.
No N20 and i didn't bech test the heads i just rough ported the intake holes 2 gasket size and soft polished the exhaust holes to gasket size. I frgt to mention headers straight out the hood no system. another thing welded spyder gears.
i didnt guess any lower because idk much about the heads. its a hard guess to make with no exact details on the heads. id say dependin on how good of a job you did it could really range from lik 11.3-12.2. my rough guess was 11.8-12.0. but adding. a 150 shot you should get 10s easily but i believe the stall is goin to hold you back some and it also depends on suspension and how well that 10 bolt holds.
