Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
600whp@3470 raceweight
Old 04-16-2010 | 11:39 AM
LT1 Trash's Avatar
Default 600whp@3470 raceweight
About to tune my car on 150shot and should make 600ish. car weighed in@3470w/driver. just looking to get an estimate of what it will trap. i was thinking 130-132ish sound about right?
Old 04-18-2010 | 06:34 PM
transsam's Avatar
Not a chance!
I would say 140+. I base that off of nothing but my own trap. Mine is an auto with a tight/efficient converter, but you should still trap higher than I did. I trapped 137. Your manual should trap higher if you are putting down 600 rwhp. You have may not have quite the power I do, but you may have a little more. Two things are for certain. (1) your car weighs less with driver. (2) your manual should outrun my auto in terms of trap speed.
Like I said, 140+ is my assumption. Let us know if I am wrong!
Old 04-18-2010 | 06:59 PM
Sarge_13's Avatar
Just going off your sig, how does 357+150=600rwhp?
If your sig is still current, with you spraying I'd say 128-130.
Old 04-19-2010 | 01:42 PM
unit213's Avatar
Administrator
Originally Posted by transsam
Not a chance!
I couldn't disagree more with your post. No disrespect of course.
He'll trap around 132-133mph most likely at almost 3,500lbs.
I'm curious to see a response to Chris' question too about 350 + 150 = 600?
Old 04-19-2010 | 04:25 PM
transsam's Avatar
No offense taken. It does make me scratch my head at my 137 though. I always thought it was a little low because of the auto with the stall. Oh well, the single digit is what I wanted!
Back to the topic: I am a little confused about the math too. I would guess something is missing from the OP.
Old 04-20-2010 | 03:34 PM
LT1 Trash's Avatar
sorry guys, yea the sig mod list isnt updated. the car currently has PRC stg 2.5 ls6 heads/tsunami cam package from TSP and put down 444whp. ill be retuning on e85 looking for 450+ and hitting it with a 150-175 shot. ive got the Nitrous Outlet 98-02 specific plate kit on it
Old 04-20-2010 | 05:29 PM
transsam's Avatar
Just be careful with the 175 shot. I know a lot of people have pulled it off, but I know of people who have blown heads or entire engines looking for the extra few tenths or mph. I wish you the best of luck as I've had my share, but don't blow the motor! Be careful. I see most of your time being picked up in your 60'. Go progressive or in stages. A 150 shot out of the hole and your engine AND rear could go. If they hold, your 60' will probably be worse!
Old 04-21-2010 | 10:44 AM
unit213's Avatar
Administrator
You're going to spray 150-175 out of the hole with a T-56? Forget about my post above, if
you've never made a pass on the sauce yet you're probably not even going to make a clean pass.
I hope you have a built drive train and a stout clutch.
Old 04-21-2010 | 10:52 AM
LT1 Trash's Avatar
car only sees the track every now and then and i dont plan to spray 150 out the whole. i DD the car and run it on 555r's so im sure i would blow the tires off in 1st. i do have a progressive controller that ill mess with once i hook it up, but doubt ill even bother with 1st gear unless i get some mickey's on the car.
Old 04-21-2010 | 12:27 PM
Bitemark46's Avatar
A buddy of mine in a 98 cobra that put down 603rwhp trapped 131 with a 5 speed. Weighed 3400 with him in it.
If I were you I'd make a 60ft pass then shut down then an 1/8th, then a full one. If you have any suspension issues you're gonna find out on the first hit. lol. Be careful.
-Mark
Old 04-21-2010 | 01:31 PM
unit213's Avatar
Administrator
You're going to need some time to dial it in and figure everything out.
I wouldn't expect much the first time out. Stock 10 bolt? Stock clutch?
Old 04-21-2010 | 01:38 PM
LT1 Trash's Avatar
10-bolt yes. another reason why its only been to the track 3 times. monster lev 3 clutch. i wont be launching the car hard for another few months until i build an 8.8.
Old 04-21-2010 | 09:28 PM
Sarge_13's Avatar
With that much power and a stock 10 bolt and transmission, I'd say you'll run a 30 minute 1/4 mile cause they'll have to load you up on the flatbed and clear the **** off the track from your drivetrain exploding.
