Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
tbss cam and springs. buy??
Old 01-25-2011, 07:29 PM
gxp-miller-gxp's Avatar
Default tbss cam and springs. buy??
Wow that's little . I have a Stock TBSS cam shaft and springs that i could sell . It's the same a LS6 (ZO6)
204/211, .525" 116lsa
+ retainers
friend said he will sell it all to me for $150, and that i could expect 20 whp and with tune maybe more?
tell me what you think, thanks!
Old 01-25-2011, 07:50 PM
CenTexSS's Avatar
If I remember correctly, there was a member who did a LS2 cam in his MCSS, got a lot of noise, and didn't gain much. I believe another member did one also, and didn't get much either.
No one really has done a successful cam swap and laid down great power and 1/4 mile times. Mongoose makes pretty good power, but he's spent a ton of cash and I don't think he's ran the 1/4 mile yet.
Old 01-25-2011, 07:57 PM
ImpSS07's Avatar
1. buy it
2. dyno your car
3. install it
4. tune it
5. dyno again
6. give us the results
6 easy steps to success!!
Old 01-25-2011, 08:00 PM
lol thats alot more money then i plan to spend, buying it and tuning it would be as far as i go, and telling u my new 1/4 time
im not sure if i want to buy it now though considering the posted "noise issue"
Old 01-25-2011, 08:17 PM
CenTexSS's Avatar
The noise issue I'm not sure what it was. It's an older post from a couple years ago. Just have to find the right combination of parts. Research it in our section, there's a bit of info you can find that pertains to this cam.
Old 01-25-2011, 09:23 PM
LS1>girlfriend's Avatar
That's not an LS6 cam if the intake and exhaust you posted are correct.
http://www.smokemup.com/tech/ls1.php
Old 01-25-2011, 09:45 PM
DavidGXP's Avatar
I'd be more interested in using the 2000 LS1 Corvette cam with some 1.8 rockers.
P/N 12560968 (Y car cam)
198/209 115.5 LSA
.500/.500 1.7 Valve lift .529/.529 with 1.8's
Peak power at 5600 RPM in the LS1, and in a LS4 I'd say 5800 peak with a 6200-6300 shift.
Nice.. mild.. cheap, non DOD, cam for our engines. I'm sure we would see 25-30 whp with this cam and rockers.
Old 01-25-2011, 09:48 PM
DavidGXP's Avatar
Originally Posted by ImpSS07
1. buy it
2. dyno your car
3. install it
4. tune it
5. dyno again
Agreed!
Same dam dyno, same dam gear, on the same dam day!
Old 01-25-2011, 10:14 PM
Battle_Ravage's Avatar
Originally Posted by DavidGXP
Same damn dyno, same damn gear, on the same damn day!
Good luck with that. Unless you use an engine dyno.
Old 01-27-2011, 10:50 AM
707chance's Avatar
Default cam
Sittingmongoose did try a LS6 cam, didn't like the results and had to upgrade.
Old 01-27-2011, 11:25 AM
AlabamaGuy's Avatar
I don't see any reason in putting an off the shelf cam of any sort in these cars. The money you will be spending will be on supporting mods, parts, and labor rather than the camshaft itself (in the scheme of things). There's really no reason not to wait another month and save up the money you need to have a reputable shop, or comp, spec out a custom grind for you.
Old 01-27-2011, 11:37 AM
I dunno if we have any reputable shops around here. I could be wrong.
Old 01-27-2011, 11:41 AM
AlabamaGuy's Avatar
In Louisiana? Give Pat G or EPS a call. They make some of the BEST cam only numbers with LSx engines.
Old 01-27-2011, 11:42 AM
Location?
Old 01-27-2011, 11:46 AM
AlabamaGuy's Avatar
Location?
Baton Rouge, if I remember Correctly.
Old 01-27-2011, 11:48 AM
AlabamaGuy's Avatar
5.7l with 243 heads full bolt on car and an LS6 intake.
https://ls1tech.com/forums/dynamomet...k-results.html
Old 01-27-2011, 11:59 AM
Decent drive for quality work. Whenever the time comes, I'll look 'em up.
Old 01-27-2011, 12:13 PM
94ss06gxp's Avatar
custom grinds are usually only $25-50 more than a new off the shelfer
Old 01-27-2011, 12:40 PM
CenTexSS's Avatar
Patrick G is in Victoria TX, south of Houston. He's a mod here. He has the quickest N/A G8GT out there.
Old 01-27-2011, 12:41 PM
AlabamaGuy's Avatar
Correct, he grinds on EPS lobes and does a lot of work with Jeff @ EPS.
Quick Reply: tbss cam and springs. buy??
