Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
post up eps 234/246 and 236/248 results
Old May 25, 2011 | 07:11 PM
'02SOMz28's Avatar
Arrow post up eps 234/246 and 236/248 results
Post up results of these cam selections ...prefer it to be on a 6.0 but ls1 will be fine ...getting a 6.0 next week and gunna do a 236/248 h/I with 150 shot
Old May 25, 2011 | 07:21 PM
mercccc's Avatar
i guess im not exactly what youre looking for but if it helps 235/243 .621/.623 111 in a 6.2 with prc 5.3 heads made 474/435 on a mustang dyno..3700 pound car traps almost 126
Old May 25, 2011 | 07:49 PM
Zmg00camaross's Avatar
Just got some of my cam parts from EPS I order the 234/246 still havent got the cam yet. In for some replies
Old May 25, 2011 | 09:16 PM
skimms98's Avatar
In for more results...
Old May 25, 2011 | 09:29 PM
'02SOMz28's Avatar
What lsa was it on
Old May 25, 2011 | 10:02 PM
itsslow98's Avatar
Mine should be on the dyno end of next week just finishing up the build. Itll be in an 02 ls1/t56 in a mustang. hoping for 415+ on stock 241s
Mine is a 234/246 on a 112+3
Old May 25, 2011 | 11:47 PM
Originally Posted by '02SOMz28
What lsa was it on
111 lsa. Would have gone 110 but he said ptv clearance would probly be a issue which I didnt want. If these 241 heads come off something better is going back on.
Old May 26, 2011 | 08:34 AM
dre2013's Avatar
i have a similar setup... stock bottom end LQ4 6.0L with arp bolts, lightly ported and milled 243's, eps 234/246 111lsa, ls6 intake mani. will be hitting it with a 150 shot as well. im hoping to put down 430-440whp on motor, and from other results ive seen that should be pretty easy to attain. motor will be here tues, and hope to have it on the dyno within a month
Old May 26, 2011 | 05:55 PM
'02SOMz28's Avatar
I wish it could withstand a two stage 150 shot that would be fantastic
Old Jan 18, 2012 | 01:52 PM
KC Henry's Avatar
Old thread, but thought I would share my results with EPS 234/246.
Thread Link: https://ls1tech.com/forums/11-second...can-taste.html
2 Ton car, with stock LQ9 with EPS cam, 1st gear issues so mainly only running 2nd and 3rd gear for now. 12.0 @ 111 mph.
No doubt car will be in the 11's when I can get 1st gear to work correctly.
Old Jun 11, 2012 | 06:40 PM
Stoney667's Avatar
Just dyno'd mine 6.0 block 243's eps 234/246 th350 trans, made 361whp
Old Jun 12, 2012 | 07:29 AM
KC Henry's Avatar
What size stall?
Be inetresting to see some 1/4 mile times from it now.
Old Jun 27, 2012 | 09:19 AM
Grr's Avatar
Grr
I just installed the 236/248 and its pretty awesome, TONS of midrange tq, I will try to get on the dyno this summer sometime, details are in the sig
Old Jun 30, 2012 | 10:05 AM
Grr's Avatar
Grr
http://youtu.be/HJJ1ElkEjiE
http://youtu.be/7g94_1FIFqg
This cam and head setup I put together is rediculous, still has the LS1 intake on it till winter when i swap to a single plane, and im getting nearly 2" of vacuum at 6500, hence why i shift at 6500.
The advertised duration on the 238/246 is 287/295 mine is installed straight at 108ICL with a IVC of 71.5. My dynamic compression is 9.71 which is very high for a cam of this size. These videos are very rich (11.8:1 gas equivalent) with 23* timing.
Again, the midrange tq this car has is like no other N/A LS1 ive ever been in
Old Oct 2, 2012 | 09:12 AM
Grr's Avatar
Grr
Updating my results
I changed to a PTC3800 stall with a 1.8STR, the 2.4STR 4500 I had turned into a 5500 after the H/C swap.
I drive this thing all the time, 1-200 miles a week, and with alot of compression it drives pretty good, Ive got the tune dialed in nice running OLSD. At this time i still have a untouched LS1 intake on it, and according to weight and trap speed im making close to 440whp.
Ran 11.41@120 with a 1.62 60', 3500#, shifting at 6100 as the intake is pulling serious vaccum and it makes no power up high. I feel with the intake changed it would pull to close to 7000 and pick up around 30whp and 5+mph.
I am putting a turbo on it this winter so I guess I will see how the cam handles that
Old Nov 9, 2012 | 11:13 PM
Tweek's Avatar
Ever get any numbers for your setup? Im thinking about going with the same cam in mine.
Old Nov 10, 2012 | 09:52 AM
Grr's Avatar
Grr
this thread is DEAD, i would like more numbers from people as well
I am putting my 238/246 now into a forged LS3 378, 243 heads 14.2 compression and a 5000 stall. I think it will make 530whp when its all done
Old Nov 10, 2012 | 10:28 AM
^^^ bet that thing will be nasty with the compression. My cam is installed and tuned but no dyno numbers or track times till spring.
Old Jan 13, 2013 | 02:37 PM
work in progress's Avatar
499/468 6.0 with 232/242 EPS cam still a bit rich, but havent made it back to my tuner.
Old Jan 13, 2013 | 03:58 PM
BODUKE's Avatar
Those are pretty good numbers.
