To Beat an 03-04 Cobra...
your cam at .05 is around 206/212 I would bet.
in regards to dyno numbers, it all depends on cam size and other mods, and those depend on how you use your car.
my z28 is strickly a weekend toy and race car.
if your car is a daily driver, the cam you got is a great choice.
My cam is not for daily driving or stealth..
I would think your car with a good tune, pending the dyno could be around 370-385rwhp...
congrats on the car and mods... as said earlier dont get caught up in the dyno hp wars...
I lost HP on the dyno when I installed strange dana s60 with 4.10 gears in my car, however the 4.10 made up for the hp loss with faster times at the track!!!
This is what my cam is... Sorry i couldnt do better. Please let me know if this was a good MOD.
Brand COMP Cams
Manufacturer's Part Number 54-408-11
Part Type Camshafts
Product Line COMP Cams Xtreme RPM Camshafts
Summit Racing Part Number CCA-54-408-11
UPC 036584063315
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 800-5,800
Intake Duration at 050 inch Lift 206
Exhaust Duration at 050 inch Lift 212
Duration at 050 inch Lift 206 int./212 exh.
Advertised Intake Duration 259
Advertised Exhaust Duration 265
Advertised Duration 259 int./265 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.515 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.522 in.
Valve Lift with Factory Rocker Arm Ratio 0.515 int./0.522 exh.
Lobe Separation (degrees) 112
Camshaft Gear Attachment 3-bolt
Computer-Controlled Compatible Yes
Grind Number XR259HR
Valve Springs Required Yes
Quantity Sold individually.
That is an extremely small cam. Almost to the point of not worth to me. However there are also some ls6 cam cars, also very small which came in c5zo6s, that run extremely good, so dont get down on yourself about It.
I would look at getting a 3600-4000 converter in the near future. That coupled with longtubes and a cutout would be a very nice gain.
Is your trottle body ported?
Who did the work installing/telling you what to buy/tuning.
Nice guess bane, right on!
Tech support at summitracing help with parts, said it would give a dramatic increase/ awake my ride, and TB is not ported... Guess i wont be in the 380 hp i was expecting right? Anyone had this type of cam???
#32
If you need help with what to do with your car/next mod to get/what brand/etc... Come on here and make a thread about it. That is why this website is here. There are thousands of people 100Xs more knowledgeable on ls1s than the tech support at summit racing.
Did you get springs/push rods/timing chain/oil pump?
They had good intentions I'm sure, they just went about it all wrong. Your setup could have been a lot better suited for what you are wanting for the same amount of money I'm sure, aka the shorty headers.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I doubt you will hit 380Rwhp with those mods, it would have to be on a pretty generous dyno. I personally would give it 350Rw TOPS. The shorty headers certainly aren't helping either.
I already said it earlier.. It is a small cam, just like the ls6. There are plenty of people in the mid 11s@115+ with the ls6 cam. However they do have full bolt ons/some have ls6 (243 casting number) heads/along with some weight reduction and a nice converter. MikeG is one of the first that come to mind (pretty sure that is his name, SOM Z28 IIRC).
If you want to make the most out of this cam, you need to get a nice set of heads in my opinion. Something like the AFR 205s. You can pick them up for around 1500-1900$ used with springs and cleaned.
Who did your tuning?
#33
mild cam (comp cams), w/ valve spring kit, Edelbrock shortys Headrs, no Cats, flowmaster 80 exhst, SLP Lid
380 HP... doubtful. @ 350 is a good ballpark as 12 stated.
I am not a big fan of Fords anymore since my SVT blew up, but the '03 Cobras are pretty wicked - even Stock.
I wouldn't put any money down, or talk smack on a run with him until you get that Stall at least.
good luck.
good luck.
#34
A stock one will probably be a good race with you, I'd honestly give the edge to the 03 cobra. With at the very least intake/exhaust on the terminator it will beat you and that's probably the stockest cobra you'll find on the road.
#35
Like lemons said get a converter. That cam in my opinion is alittle on the small side and not worth the money you spent. Next, you need to get a set of longtubes on the car. Watch the classifieds and see if you can't score a set of kooks or arh for a decent price. Did you port your stock tb? If not then you need to do that asap.
#38
good luck.
good luck.
#39
Answer these...
What rwhp are you shooting for?
What et are you shooting for?
Do you care how much the cam lopes at Idle?
Is it a DD? Weekend toy? How much track time and street time does it see?
What is your budget for your heads?
Anything else you expect the cam to do for you let me know.
You also need to let me know when the absolute soonest you can get a converter is. You can't go with a cam worth a damn without a converter. You will need a converter asap. I'm not going to tell you to get a 228r with a stock converter.... but chances are you would love that cam, from what I have seen you posting.. anything smaller and it isn't a waste of time but thy are very small cams.
Are the short headers installed already?
#40
http://www.youtube.com/watch?v=HwIsy...0F6650&index=1
Decent video! Good luck with your adventure man!
Vinny
Vinny
