Dyno Guesses & Bench Racing Forum Horsepower Estimates | Racing Scenarios
To Beat an 03-04 Cobra...
Old 05-28-2011, 10:15 PM
LASTOFTHEBREED02T/A's Avatar
Thumbs up To Beat an 03-04 Cobra...
Will this be enough to take these cars down?...
I Have an 02 A4 ws6 ram air package Trans Am, With a mild cam (comp cams), w/ valve spring kit, Edelbrock shortys Headrs, no Cats, flowmaster 80 exhst, SLP Lid w/knN filter. And a pretty decent driver...
Should this be enough to Take down a SC Cobra??? And what do you estimate My Total Horse Power to be if the T/A has 325 stock???
Im very excited, getting my car out the shop with all these mods done, with fresh silver paint, and a few black stripes.
Be a good sport and post your opinions, THANKS!!!
Old 05-28-2011, 10:18 PM
Empatho's Avatar
It depends on what cam you have and also on the mods of the terminator.
WSsick's Avatar
What are your cam specs? Do you have an aftermarket converter?
Cobras can be just pullied to pullied/ported to big blower swap, etc. One setup won't take them all down.
Old 05-28-2011, 10:34 PM
MY cam is...Hydraulic Roller Tappet, Advertised Duration 259/265, Lift .515/.522.
Stock converter and gears, just the mods shown above is all that i have done.
Old 05-28-2011, 10:37 PM
ULTIMATEORANGESS's Avatar
Smile
a stock one you should beat.
id get a stall and DRs and run one from a stop.
Old 05-28-2011, 10:39 PM
TransAmWS.6's Avatar
Yeah, I'd say a stock one you could probably pull on, but then again, there are really not many of them out there at all that are still stock. I think if you ran into the average pullied/bolt-on Cobra, you would have some trouble with it.
What can be expected on Horsepower gain?...
Old 05-28-2011, 10:40 PM
lemons12's Avatar
Bolt ons will take a stock one down..... If you can find one that will race and stock. Most people that will run at minimum have a smaller pulley/cai/tune (450+Rwhp in most cases).
You need a converter. I would keep the stock 3.23s.
Add a cutout, very cheap and should be a nice gain. Why did you get shortys over LTs?
Old 05-28-2011, 10:41 PM
ibanez7's Avatar
259/265 is not a mild cam, with small lift?
check the specs again..
mild LS1 cams are usually 224/224 with 580/580 lift...
to answer your questions, a decent cammed LS1 can beat a stock 03-04 cobra without issue.
it will be a drivers race, and traction race, unless its from a roll.
as mentioned above, a pulley swap and tune on a cobra makes it a new car in the HP dept
Old 05-28-2011, 10:43 PM
lemons12's Avatar
An average pullied Cobra should destroy him. They are 116+mph cars.
The dyno will actually read that you lost power. Just like if you add a steep gear ratio (ie 410s), a built 9" rear, etc...
You need to get the HP wins out of your head. A better setup car will ALWAYS outperform a poorly setup car.
With a converter (I recommend a minimum of 3600) you will probably dyno around 10Rwhp less. However, if you go with a nice company (PTC/Yank/Precision Ind./Circle D/etc), you should knock near a full second off of your ET and gain 1-3mph.
It should be THE FIRST MOD to all autos.
Ran out of cash to do more mods to the exhst... Waiting a bit to do an x pipe with lt's. Full exh is kind of xpnsv. Just spent around 1400 in parts. Not to mention labor, and the paint job.
Old 05-28-2011, 10:44 PM
lemons12's Avatar
to answer your questions, a decent cammed LS1 can beat a stock 03-04 cobra.
That is advertised... People on here don't use those numbers... People outside of here, do.
A decent cammed ls1 should DESTROY a stock 03. No offense to op, but it is not decent.
Old 05-28-2011, 10:45 PM
lemons12's Avatar
Do a converter before anything else.
graderbird2004's Avatar
I ran a 03-04 last week, a local guy who runs around a messes with everything that has wheels. He talks his car up alot, though i have not talked to him in person. His car is nothing to take lightly, sounds mean as you can get. We hit it on a back road and i pulled at least 2-3 car lenths at to 115. Of course as soon as i let off he went flying around, so i am waiting to meet up around town and see what he has done and what he thought of the race. My car is cammed, headers, mild ported heads, and fast 90/90 setup.
Old 05-28-2011, 10:46 PM
ibanez7's Avatar
LTS, ory and dumps before the rear axle is a fairly cheap setup.. that will net very big gains over shortys.
Old 05-28-2011, 10:55 PM
So the, 259/265, Lift .515/.522 Cam is not Decent, or bad? What HP do these LS1 make with the spring kit n all?
Old 05-28-2011, 11:00 PM
LS1T56FTW's Avatar
259/265 is probably at .000 Most cams are spec'd at .050, which is why you see smaller numbers such as the T-Rex at 244/248 @ .050 That cam at .000 is MUCH larger. If the OP has a 259/265 @ .050, he would definitely know it. That big of a cam in 346 cubes would probably not even start.
Old 05-28-2011, 11:09 PM
ibanez7's Avatar
exactly what I was thinking....
I barely ever see people talk with .000 cam specs so I didnt catch it at first, thought maybe his shop screwed him.
I'm running the SI5 - 231/237 595/595 112
231/237 at .05.... at .000 its 279/285 in my 346.
his 259/265, is small cam at about 206/212 at .05. It will be a good race with a 03/04 cobra, but would still be a good stealthy at DD cam.
a converter would be a great add to the car!
I would not recommend my cam or any cam 224 or larger for DD.
Old 05-28-2011, 11:10 PM
So the, 259/265, Lift .515/.522 Cam is not Good or mild cam? What HP do these LS1 make with the spring kit n all? now worried about the Hp I will see...
Old 05-28-2011, 11:11 PM
lemons12's Avatar
As stated, find out what the specs are at .050 and post those. And no a cam that size at .050 would be for a stroker.
The springs push rods etc add no power..
Quick Reply: To Beat an 03-04 Cobra...
