Going to the track again soon, predictions this time?
okay a little info:
Ran a 13.4 @ 109mph 2.21 60'
was on shitty street tires @ 30psi (no traction)
96 degree weather, drove 1.5 hours to the track and ran three times first being my best time
now ill be headed back again
since then I've added an electric cutout (good for a few hp?)
and will be on ET street radials on probably about 16 psi
and it will be about 55 degrees out, and ill be trailering the car there
just want a basic goal to have, was pretty disappointed last time I went.
You should be able to run better then 13.4 just with the mods you have, maybe the radials will make a bigger difference then I first thought. I would look in to a tune and relocation brackets next to drop the 60'. What RPM are you launching at?
it was street tuned at lingenfelter, i have adj bmr torque arm, relo bracket lower control arms, bmr springs
I hope drag radials will be the main help, i was spinning bad, and he car was HOT
