estimate hp and 1/8 mile?
hey guys i have a 99 trans am full bolt on. with full bolt on and 100 shot i ran 7.7x's in the 1/8 with traction issues. i just did 241 hand ported polished and chamber work to the 241 the porter claims they would flow equal to the ported 243, ms3 cam, 390 gear, spool, and connecting now the trans brake. dropped about 500 pounds off of her and counting. got about 150 200 more to take off. rest of the mods on sig. i will be runing it on and off the bottle 150 hit and a future 200.
what do u guys think it will run? upgrading tires before i take it out, to some bfgoodrich 28x10 or mickeys et streets .
now power wise the porter said id be close to 450 the tuner says ill be close to the 500 range witch i doubt but that's the estimate on hp. plus a 150shot witch ill guess it will give me 100 to 120 hp to the wheels.
is this better? would u need some more info? id like to get the car to 3000 31somthing with roll cage done.
Density Altitude (google it and read for days!). Bottom line the lower the DA the better the car will run. My track is at 36' above sea level and the DA can vary from -2000' to +2800' depending on temp, humidity, baro pressure, dew point and grains of water. Go to www.dragtimes.com for the track nearest you. My bracket car will vary up to .5 sec. depending on DA
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Density Altitude (google it and read for days!). Bottom line the lower the DA the better the car will run. My track is at 36' above sea level and the DA can vary from -2000' to +2800' depending on temp, humidity, baro pressure, dew point and grains of water. Go to www.dragtimes.com for the track nearest you. My bracket car will vary up to .5 sec. depending on DA![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
yea i was hoping a mid 6 but im happy braking in to the 6's period on a street weekend car. i know i wont dead hook. i wasn't hooking before, but i will be trying the bfgoodrich 28x10.5 to see if i have better luck. my cuz has a set of hooisers that he can lend me also.
ok i looked up some more info these are the number for the next couple days estimate for the track
Track elevation: 91.9 ft.
highest
08/16 11:00 AM
Temp..................92
Humidity.............54%
Barometer...........30.00 Hg
Dew Point............73
Grains.................122.0
Air Density...........91.88 %
Density Altitude....2870 ft.
lowest
08/16 02:00 AM
Temp.................77
Humidity.............90%
Dew Point............74
Grains.................125.7
Air Density...........94.37 %
Density Altitude....1970 ft
highest
08/16 11:00 AM
lowest
08/16 02:00 AM
thanks for the info man appreciate it. i hope this combo works out well. im just a lil worried about the diff but oh well ill take it as it plays along. hope to be procharged next year with a 9 in the rear.
id just run a mickey thompson and then itd prob hook. buy you a gallon of pimp juice if not. play with the tire pressures. find out if it likes a little heat or alot. i dont know much about that particular radial. im feeling a 6.70 tho. the tq youll make off the line is going to need a serious tire.
i was hoping to brake in to the 6's on motor is that what u guys are say or u guys talking about on bottle 6.90s ??? have to finish the interior and the ill weight the car see what it weights.
