Estimated HP gains.
Sup guys, just curious as to if there was a site that or if anyone knew an estimate of how much hp gain you will get from each mod?
CAI , Headers, full exhaust, cam, etc..
searching will let you see some rough estimates but it's all benchracing...
better off just doing the proven mods: air lid (do NOT do a cold air intake with 90* bends and piping or the K&N thing that sits on top of the radiator), headers, 3.5"-4" off road y or dual exhaust, LS6 intake manifold since you have a 2000 (01-02 cars had it stock), and a ported stock throttle body if you can get it done cheap and a good tune for those mods (either reputable mail order or dyno tune...no programmers)
after that look at a cam, pushrods, valve springs, timing chain, and new oil pump since it all should be done at once
I want to dyno my car but I am broke lol called lashway a local dyno tune place someone told me $600 don't got that now.. just got the car and it has mods
Fast 90/Nick williams 90mm
cam
comp valve springs and pushrods
cam
pacesetter headers
ORY /corsa 3'
SLP lip free mod with K&N
4.11 12 bolt
Manual 6
hopefully I can do it next month..
cam
cam
pacesetter headers
ORY /corsa 3'
4.11 12 bolt
Manual 6
cam
cam
pacesetter headers
ORY /corsa 3'
4.11 12 bolt
Manual 6
cam
cam
pacesetter headers
ORY /corsa 3'
4.11 12 bolt
Manual 6
The guy I got it from told me he got it tuned a few years back.. but I just want to see and have on paper the current HP and while i am there make sure that the car is tuned correct. do tunes go bad or alter some how over time?
I would do a dyno pull and maybe pull the plugs for now and read them if you can or post pictures and ask. See if it is running to lean or rich if you can afford to get it retuned.
depending on cam, should be around 390-410rwhp or so
I would get them to dyno it with air fuel monitored and if it is safe leave it alone...no point tuning a tuned car with correct air/fuel ratio
unless the tune is locked it should be free plus whatever the tuner charges for his time to look at the current tune, you do not have to buy credits to look at it
