SBE ls1, 241s, VRX5 cam dyno guesses?
I have a dyno date scheduled for next week and I wanted to get some opinions on what I should expect for power/torque. My setup is:
Stock bottom end ls1
Pro-comp 96mm intake
NW102 TB
MTI lid
Stock injectors
Vengeance VRX5 cam(236/238 .601/.605 113+3)
Stock casting 241s w/fresh rebuild
Stock rocker w/BTR trunnions upgrade
Morel 5315 lifters
Tick performance 5/16" hardened pushrods
Ls2 timing chain
Pacesetter 1 3/4" long tubes
TSP 3" rumbler true duals
Built 4L60E w/pro torque 3000 stall
Speed density tuned
What do you guys think she will put down?
NW102 TB
MTI lid
Stock injectors
Morel 5315 lifters
Ls2 timing chain
Speed density tuned
Originally Posted by elephantrider
just saw this and was going to say your going to run out of injector with
that set up
that set up
Originally Posted by carolinaSS
Nice man, hope it runs good.
Skip the dry shot and run a wet plate unless you plan on running a different OS to control fueling. Relying on the stock pcm to add fuel for the spray is not the best way to do tbings. Unless we are talking about 75-100 shot blowing through the maf? In that case 60lb injectors are OK if you can find some that have good data with them for tuning. That is the biggest problem with big aftermarket injectors is finding good data to tune. Most end up with botched ifr tables and the car drives like ***.
Just a quick update. I got the 60s in and made a couple WOT runs on the street. It's still wanting more fuel. I had to stop cause I passed to local cop while I was on my way back to town. Had we met 3 miles sooner I would have given him one hell of a fly by.
