Which setup should be faster
Martin isnt at Tick anymore, But I do like their grinds still. I will for sure do more research first and ask around as well. I was thinking the 243s would bump up compression a bit which is why I was thinking of going with those.
Yeah I was more referring to the general specs of the SNS 2 which is why I threw that one out there. But if you're going to work those heads over then that might change the game plan again
100 shot like he said shouldnt be too huge of a deal. I will run N/A 95% of the time anyway. Also an update, Yank is going to let me switch out my ss3600 with a 4000. I think it will help a lot with a large cam
#34
With that low of shot you want it to run good NA and when you spray you will not need anything but pull a little timing and push the button. There is no "nitrous cam" for that small of a shot. Any cam grinder will custom grind you a cam with NA specs for that size shot. If you give him same motor combo but say it's a 250 or 300 shot the grind will change.
#35
I figured change the plugs over to the br7's and install a LNC for the nitrous and it should be good for a 100 shot regardless of cam really
#37
still contemplating going with the 4000 stall. I know it may not be as fast on nitrous or good for street driving but 95% of the time I would be N/A and on the track or driving to the track.
