What will it run? Dyno update
1987 iroc
2000 ls1 short block
243 heads, shaved .025, fresh valve job, bowls blended into seats, exhast and CC polished
.040 cometics
TSP 224/224 .600 .600 112 lsa
Fast 90/nw92
36lb injectors
truck coils
walbro 255
85mm maf screen removed
1 3/4" longtubes 3" collector dumping into single 3.5"
yank ss3600
strange 12 bolt 33 spline with 4.10 gears
lakewood adj. lca's
weld in subframe connectors
Mickey thompson street meats
My local track is at 550 ft. above sea level. I don't know what the typical DA is.
What's your prediction for 1/4 e.t. and mph?
.040 cometics
Fast 90/nw92
36lb injectors
truck coils
walbro 255
yank ss3600
lakewood adj. lca's
I can run as fast as 11.50 at my local track before needing cage work. I'm not installing a cage. Not really sure what I could do for weight. The car is nearly mint so I'm reluctant to do much to the body or interior. Any thoughts on what it might run with current set up listed?
All depends on traction. That car should weigh a lot less than a 4th gen. Especially with the LS1 in it. That's a 100 pound savings over a SBC motor instantly, my 92' formula tipped the scale at 3300ish from the man so the motor swap alone has it at 3200 race weight. 3600 stall and motor mods FTW IMO. Where you running at? Dinwiddie or Richmond?
