Power Estimate
547flywheel/ 473.3RWHP
16 months later, the engine is together on the K Member. Waiting on converter to get back from Circle D for a restall.
Made changes to the intake, Vic Jr with that low profile eLbOw. Intake is port matched to the PRC 227 heads. Had a 102 adapter tigged onto the elbow then polished the inside. The rear hump cut back and smoothed. The divider rounded on one end and knife edged on the back, like an air foil. The cam changed to 240/250 111+4 .629”/.612”.
The following users liked this post:
00pooterSS (04-13-2020)
LFSADRG (03-28-2023)
Nearly three years later and the car is together. It starts with an initial tune. First oil change done. No leaks. Need to adjust the Viking coil overs for ride height and still fighting the TSP Rumbler exhaust so unable to get on the road.
Couple of changes to the drivetrain: 3.90 gears with a Nitro Gear helical worm gear diff. The converter was tightened up from Circle-D. For the trans, replaced the stock wide ratio 3.06/1.63 planetary gearset with the Sonnax close ratio 2.84/1.55.
The following 3 users liked this post by LFSADRG:
