4500 accufab on a stock ls1
Ive got a stock ci ls1 that has a cam and spring upgrade only. its a drag only car runs 6.70,s. currently has a super victor with elbow and a 90mm single blade throttle body on it.open headers. I was given a accufab 4500 TB with adapter to fit a 4150 flange to try. Is the 4500 too much even though it is drag only?. And if it is, could it work using only two barrels of it?
Your engine can handle only so much air for a given setup. If the present 90mm TB is feeding the horses and it likely is, a larger one won't increase power.
No way to duct air to the present TB? If you change it over, you risk actually losing power with an unknown setup.
The following 2 users liked this post by spanks13:
Kfxguy (11-01-2019), SUPERIORMOTORSPORTS (08-06-2019)
