Cartek built 1000 hp w/blower complete!!
I’m selling my Cartek built 347 with f1a blower complete... This set up made over 1000hp at the crank and had ran a best of 8.75 at 156mph in the 1/4 with a 3200lb car with only 18lb of boost...
Everything from the intake manifold to the oil pan!!
Motor spec as follow
Cartek/Diamond forged pistons
Manley severe duty rods
Balance crank
Clevite rod and main bearings
Cartek Custom 2x boosted cam
Double roller timing chain
Cartek stage 4 heads
serdi valve job
Cometic head gasket
Evans high flow water pump
Ls6 intake manifold
Tb ported n polished
polished fuel rails
120lb injectors
polished F1a pro-charger blower
Polished procharger bracket
8 rib pulley set up
Plugs
Wires
Coil packs
Plus much more!!
Here is your chance to buy a proven set up at a fraction of its org cost... I have over 18,000.00 in this set up... The blower alone retails for $3700.00 and that is not including the bracket..
Cost is $11,000.00
Any more info on this set up you call me, Sonnie 215-868-8162 or Cartek..
There is nothing wrong with this motor at all.. The reason for me selling my set up is that I have something else in the build for next year.. No I’m not saying what it is either. If you buy this motor I will be more then willing to discuss my new build with you...
Balance crank
serdi valve job
Cometic head gasket
Ls6 intake manifold
polished fuel rails
120lb injectors
8 rib pulley set up
Plugs
Wires
Coil packs
Plus much more!!
Cost is $11,000.00
