My build thread, sort of...
A couple of years ago (almost exactly) I ended up punting the car into a curb and broke the rear end. At that time it had TFS 215 heads and a TR230 cam in it that made 460hp through a set of 4.10 gears and the stock rear. It was loads of fun to drive and had incredible mid range oomph.
With the engine complete, I attached the spec flywheel and dual disc clutch along with my T56 trans which had been rebuilt by T56 Rebuilds (SixSpeedInc) a few years back. The assembled unit then onto the k-member and into the car (big thanks to my brother Scott for the help in lining things up). Along with the motor and trans, I installed a Moser 9 inch with TruTrac and 3.89 gears (also set up by Sean at Va Speed). I also put a UMI tunnel mount adj torque arm and Watts Link on the rear. After that, it was just a matter of bolting up all of the components that I had removed before (brakes, rear suspension, interior, etc). Easier said than done as I’m sure anyone knows who has tackled a project like this over an extended period of time. Lots of time wasted looking for bolts, nuts, and screws that had mysteriously disappeared into the black hole that is my garage, not to mention seemingly endless trips to the hardware / parts store for misc items.
http://www.youtube.com/watch?v=u30GX3yaw9Q
Hopefully this weather will clear up and I can get a better vid this weekend after I wash it.
