Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Paging Purevl
Old Oct 19, 2005 | 06:51 AM
lilstephsls1's Avatar
CT Hotness
Default Paging RhodeIslandRed ;)
Rumor has it that you are good in C++,
is this true?
If so can I ask you a few questions??
Old Oct 19, 2005 | 07:56 AM
DannoWS6's Avatar
Post it up Steph.
Old Oct 19, 2005 | 08:16 AM
PurEvl's Avatar
oh god Ya i was about 15 years ago..I havent programmed in a long long time, other then scripting in linux and what not
Old Oct 19, 2005 | 08:26 AM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
You can prob find a bunch of up to date people on a forum, just do a little Google searching.
Old Oct 19, 2005 | 09:59 AM
CT Hotness
maybe you know this then danno, its pretty simple but i cant find an answer. I am using a function to ask the user to enter in a number that they can pick between 9 different commands to do (ie add, subtract, modus, multi..etc). So i have to ask the user to enter a number between 0 & 9 depending on what action they want. Now if they enter a 10 or anything else, I am suppose to terminate the whole program. How the hell do i make the program terminate? Do i use 'return 0;' during that function, or do i use another code?
Old Oct 19, 2005 | 12:11 PM
JSTAN's Avatar
You will have it return 0 during that function......below is an example written in Perl of a script I use....as you see, if you dont enter the correct value, it will fail and promopt you to enter another value...it may also work with C++
sub prompt_phase {
my ( $ans, $subr );
print "\n--------------------------------\n";
print "Please select a phase to execute\n";
print "--------------------------------\n";
print "0. Run steps 1,2,3\n";
print "1. Generate the list of streams for Depot: $::depot\n";
print "2. Examine the contents of each stream\n";
print "3. Scan the stream contents for evil twins\n";
print "Q. Exit\n";
print "\n";
print "Enter Selection: ";
$ans = <STDIN>;
chomp($ans);
exit 0 if ( $ans =~ m/q/i ) || ( $ans =~ m/x/i ) || ( $ans eq "" );
if ( !( ( ( $ans >= 0 ) && ( $ans <= 3 ) ) ) )
print "\n\007$ans is not a valid selection\n\n";
return;
$subr = "phase_" . $ans;
no strict "refs";
&$subr();
use strict "refs";
Old Oct 19, 2005 | 12:41 PM
ARROWSS's Avatar
Coach Purse Queen
Yea for perl! /fellow perl coder
Old Oct 19, 2005 | 12:55 PM
8ALTNG's Avatar
Im not going to lie. I have absolutly no idea what you guys (and gal) are talking about. I guess thats why I'm a farmer
Old Oct 19, 2005 | 12:58 PM
Rhode Island Red's Avatar
Cool
1) print out user options
2) read for user input (using an individual char)
3) determine whether a character is a digit (use "isdigit(insert_variable_here)" (include ctype.h) when used it will return 0 (false) if the character is not a digit and 1 (true) if it is....so an ex: "if (isdigit(c)" ... in addtion you need to also check for the letter Q . so a combined statement such as [i]if((isdigit(c)) || ((c == 'q') || (c == 'Q')))if it isn't the input you need,you can clear the scree, and redisplay the options or an error statement or a combination of both.
4) once it is, and bad inputs filtered out, perform a switch statement within the if statement for each option accordingly
Old Oct 19, 2005 | 01:05 PM
CT Hotness
okay that helps. I am also not sure on a void function. I know I have to use this function to print out a menu of options to choose from. It is supposed to display something like this to the user (this is shortened):
'accumulator=0
1) Enter number
2) Add
3) Subtract
4) Mutliply
Please enter a number from 0 to 9:'
How exactly would i use a void function to display this to the screen?
Old Oct 19, 2005 | 01:10 PM
void display_the_menu (void)
cout << "1) Enter Number \n"; //or printf("1) Enter Number \n");
you use a void only when you expect the function to return nothing
in your main procedure, call this function, then read the char, then call the processing function and pass it the character (by value) . and go from there
Old Oct 19, 2005 | 01:17 PM
CT Hotness
i get so confused on this stuff. That makes sense but when you say you don't want it to return anything, does that mean it just goes on to the next function or loop that is next?
Old Oct 19, 2005 | 01:23 PM
if the called function does not return anything and the program finishes going through it. It continues down the code and processes the next line of code. Once your finished with the function, that's it your finished with it, even if the function returns something. You could have the function in a while loop, or any repetitve loop, and while the condition is not met, example ((while c != 'q') || (c != 'Q')) run the program.... so in short YES
Old Oct 19, 2005 | 01:29 PM
PurEvl's Avatar
steph i would definetly listen to cheesy on this ****...hes been coding a long time
Humanitarian
Cheesy is the Eastern C++ rep.
We found something your good at!
Old Oct 19, 2005 | 01:33 PM
CT Hotness
i am trying hard. I just suck at this ****.
okay i am trying to run the program just but i am coming up with errors regarding my 'display_menu'. Where the hell do I declare that?? . THis is what my program looks like so far:
#include <iostream>
#include <cmath>
#include <iomanip>
using namespace std;
int main ()
//declare and initialize objects
double accumulator(0);
char display_menu;
//ask the user to enter a number that will be the accumulator
cout << "Enter a number ";
cin >> accumulator;
void display_menu()
cout << accumulator;
cout << "2) Add \n";
cout << "3) Subtract \n";
cout << "4) Multiply \n";
cout << "5) Divide \n";
cout << "6) Modulus \n";
cout << "7) Raise to power \n";
cout << "8) Square root \n";
cout << "9) Negate \n";
cout << "0) Exit \n";
cout << "Please enter a number from 0 to 9 \n";
return;
return 0;
Old Oct 19, 2005 | 01:45 PM
move the display function outside (and above - traditionally) the main procedure. C++ likes independent procedures. No need to have functions declared within functions with this one.
hint: usually you can trace an obscure error to the earliest line in the program, you understand,if the error is not so obvious. An coding error can create following errors as a result, that are actually not code errors, but the compiler unable to properly interpret the rest of the code after the error (usually syntax errors)
oh , and remove the "\n" and add ": " instead at the readline. People are used to entering at the line commanded, unless the command is quite long
Old Oct 19, 2005 | 01:59 PM
Tracer X's Avatar
LS1TECH Sponsor
I told you guys Cheesy is a smart motherphuker! I just didn't know at what.
Old Oct 19, 2005 | 02:42 PM
CT Hotness
awesome!! i just went to get a little help from the teacher and he talked me through some of it. I feel so helpless when it comes to this ****.
Old Oct 19, 2005 | 04:37 PM
CT Hotness
thank you so much cheese. i got it to work finally. For some reason i thought i could put the void and double functions inside the main function, which caused me to have about a million errors and freak out. After all that shananagans, the rest was pretty simple. I had to use a switch statement to give me the calculations and whatnot. That stuff seems pretty easy. Thanks for your help again!
