Maybe one of you Pro's can help me with my tranny problem
Hey guys, just wanted to call onto your almighty knowledge
Problem: 4l60e
At 1200 RPM's in 1st a bad vibration coming from the drivetrain
In 2nd around 2000 RPMs same vibration.
On hard accelerations the bad vibration continues
Tried fixes:
I've tried replacing the trans fluid, filter, and gasket.
I've also checked the yoke, and there seems to be a good amount of play there.
Any ideas may help. Thanks guys
Chris
Problem: 4l60e
Tried fixes:
Chris
I have not checked the tranny mount, but may do so tomorrow. If it's nice that is. Calling for snow
However, there is no slipping that I can tell of. Just the bad vibration. If I hold it at exactly the right RPM there is a ticking, or a clunking from the tranny/driveshaft area. Maybe the u-joint area.
Don't risk driving the car. If it's not the tranny mount. make sure you check everything. If your driveshaft lets go from the front while driving, you could wind up dead. Make sure your yolks and u-joints are secure!!!!!!!!!!!!!!!!
Yeah, I'll look into that. I just wish I had another driveshaft to swap into the place of the existing one. That would make it real easy right?
Just pop that one in....if it doesn't do it, then there is a problem with mine
