Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
blew my motor with nitrous
Old 03-02-2006, 12:58 AM
anthonyz281999's Avatar
Default blew my motor with nitrous
i guess i knew it was a bad idea from the start...but i had done a lot of reading and was told that if i run 100 shot that i should be ok ....i hooked it all up perfectly went over it twice..had my friend go over it...all looked good...i worked my way up with the pills...worked great with a 50 and 75....then when i put the 100 in i hit at like 40 just above 3000 and i heard a clanking and something blew out the side ( i assume) oil poured out and now i have it towed home.. well im in the market for a new block and wat ever else i broke...anyone got any suggestions or ideas...and tryin to find a cheap car for now...say i get a new block and parts..how hard/long would it take to change in my driveway if possible ??? any info/help is much apreciated ... thanx
Old 03-02-2006, 01:56 AM
ULTIMATEORANGESS's Avatar
time for a stroker.
Old 03-02-2006, 02:01 AM
if i had the money...i dont even think i can afford the stock **** lol
Old 03-02-2006, 04:00 AM
My84Z's Avatar
Dry or wet? if dry did you shoot in front of the maf? cause a 100 shot should be easy on a stock ride.
Old 03-02-2006, 04:02 AM
dry....ya did it in the lid ...before the maf and the IAT
could it have been the plugs goin bad or i hit it to soon
Old 03-02-2006, 04:05 AM
Jersey_TA's Avatar
How many miles did you have on the motor before you hooked up the nitrous?
Old 03-02-2006, 04:06 AM
it had 80k on it
Old 03-02-2006, 05:15 AM
LS1Tech Sponsor
Slowhawk's Avatar
Well,you learned an important lesson.The fuel system couldn't keep up.Your motor could also be hurt alittle before the shot and the juice just took it out.
Old 03-02-2006, 05:25 AM
1RawTA's Avatar
yup, im also not a huge fan of dry shots, in my eyes a wet just seems a little bit safer. good luck getting the car back together
Old 03-02-2006, 05:26 AM
tektrans's Avatar
I got rid of my nitrous shortly after I split my driveshaft in 1/2 an cracked the trans on a nitrous launch. Can't afford the repairs so I ditched it.
Old 03-02-2006, 06:50 AM
8 second mod
Noyzee's Avatar
if it blew at 3000 rpm, when did you hit it?
if you need used stock parts, let me know. i have rods and a crank i will get rid of them real cheep if it will help you out.
good luck.
ps, a good set of pistons, a fuel pump, and a good tune, 100-150 shot will be easy!
Old 03-02-2006, 09:17 AM
CARTEK Racing
WS6TransAm01's Avatar
Sorry to hear that,
I was lucky enough to escape with no damage after I had a wet kit on my car [75shot] for about a year.
Just another reason why, even though Nitrous is so tempting because it is the cheapest way to go fast, it will never again touch my car.
Good Luck!
Old 03-02-2006, 09:52 AM
99zman's Avatar
i learned the hard way also in my mustang that i had, the **** works no doubt but, like i was told after i spent about 2g in repair its all in the tune!!!!! after i got it tuned never had a problem, and i was running a 150 nx shot. sorry to hear about your car..
Old 03-02-2006, 10:07 AM
LS1Tech Sponsor
Slowhawk's Avatar
Nitrous can be very safe if you have enough fuel, good tune and the right safety's. I ran a TNT wet shot on my Hawk when it had 800 miles on the car.Went through 15 bottles in 2 months.Car made 460hp 560tq.
Kind of funny though.Back then I ran Nitrous and Noyzee was going Turbo
Old 03-02-2006, 12:19 PM
8 second mod
Noyzee's Avatar
i remember that. both have steped up tho, baby shot to big shot, baby turbos to big turbos. lol
Old 03-02-2006, 12:30 PM
DannoWS6's Avatar
That sux man.
I would think a good running fuel system could support a 100 shot w/ bolt ons. Something must of been wrong. I'm sure one day I'll spray her (wet), you better beleive I'll have Don keeping tabs on her on those 1st few pulls
I guess now it's time for you to think BIG.
Old 03-02-2006, 03:56 PM
BTLFEDSS's Avatar
Were you on stock plugs should be running NGK TR6's.any saftey switchs like fpss or a/f guage in or on the car to see if it went lean.Don't i think would be a fuel problem as i sprayed 100hp which is 80rwhp on smaller 26.6 injectors stock fuel system.Just some things to think about
BTLFEDSS
Old 03-02-2006, 05:12 PM
anotherreject04's Avatar
what kind of safty backups did you have? fpss? anything? cause ive been starting to look into the spray
Old 03-02-2006, 05:21 PM
INTENESS's Avatar
I have stock shortblock with 35000 miles on it out of 2001 SS That is ready to go in.For sale cheap.
Old 03-02-2006, 05:23 PM
Moderator
davered00ss's Avatar
Swap should take 2 days and can be done in your driveway. Pull it from the top.
