1st Nite out being Cam Only!!!!
well i first run i had to hit the breaks and let off twice due to the car aiming for the wall, ended w/ a
1st pass
12.5 @114 hit a 1.61 60' leaving at 5500
this is due to what i kinda expected, a bent and/or cracked stock TA and posibly the rear sway bar. so i took my buddy's advice after thinking it over and adjusted the LR to 13psi and the RR to 15. this got it straight resulting in a
2nd Run
11.9 @ 119 w/ a 1.71 60' leaving at 4k.
3rd run same tire pressure launched at 5k
60'- 1.68
330'- 4.884
1/8-7.537
MPH- 92.30
1000'- 9.804
1/4- 11.691
MPH- 120.47
4th run
NEW BEST......
tire pressure 12psi LR 14 psi RR
launched at 5k
60'- 1.677
330- 4.873
1/8- 7.516
MPH- 92.54
1000'- 9.776
1/4- 11.657
MPH- 120.70
i was on my ET Streets. in street trim, pass seat,carpet, front sway bar left in the car.
now for a TA,Rear Drag Sway Bar,K-Member,A-Arms,race battery and the above items removed.
i will see a 11.0/10.9 pass cam only.
not bad for the first nite out.
oh yeah and btw i blew a header gasket on the second pass, and got worse each run.
-brandon
1st pass
2nd Run
60'- 1.68
330'- 4.884
1/8-7.537
MPH- 92.30
1000'- 9.804
1/4- 11.691
MPH- 120.47
4th run
NEW BEST......
launched at 5k
60'- 1.677
330- 4.873
1/8- 7.516
MPH- 92.54
1000'- 9.776
1/4- 11.657
MPH- 120.70
-brandon
In the past I had doubted that was a stock internal car. Now it appears it was, since you gained so much MPH with that cam in less then stellar weather. Very impressive!!
That car runs like a cammed LS1 should, 120 MPH is getting it done!!
