rear drag bar
. and when its spinning(top notch nanking tires suck
) it stays perfectly straight too.
Two wheels up high!!!!!
That's makes two of us that can't wait for Spring '07!!!
I did the big mod I was awaiting and now I have to wait too.... Just like with the STS... this time though, the GTO stays away all winter... No Feb. falling asleep behind the wheel....!!!!
Which one did you end up putting in, the bmr or the spohn? it's the one with the rod endd mini ti-rods connecting it to the body yes? Can't really tell from the pic.
the shocks will be evened out next spring thats for sure , its gonna be nice not having to max the adjuster out lol. i was 8+" on the drivers side and 1-3" on the pass. side front wheels with the pass side shock maxed . it was defiently time to change that
ill try to get the link pics tonight if i can, easy as hell to setup and install thats for sure. the shocks will be evened out next spring thats for sure , its gonna be nice not having to max the adjuster out lol. i was 8+" on the drivers side and 1-3" on the pass. side front wheels with the pass side shock maxed . it was defiently time to change that
ill try to get the link pics tonight if i can, easy as hell to setup and install thats for sure.that's what I've been told, about the spohn bmr and the wolfe bar alike.
I have had good lusk with the spohn one I am runnign so far, but it's the bushing mounted one, not the one with the weld on tabs.. when I need somethign stiffer, I will probably put a wolfe on, more because when people see that type they know you're not messing around LOL.
That should help alot though I'm sure.. just gonna be a little learning curve with the shock adjustments.
That thing should put them sky high now.
