Turbo or Procharger? hmmm MrB, slowhawk
Originally Posted by 8ALTNG
what other mods are you going to do??? bottom end, heads, cams??
Race your car!
procharger will have that big block feel to it.... but with the auto and the right converter, the turbo could probably feel the same way.
Either option will make for a fun car.... just depends if you want to have to change a pulley to up the boost or do it with a boost controller/wastegate spring.
Now's the time to make the decision.. while there's nothing done so you're not undoing other mods (like going turbo after buying headers, that sort of thing)
Originally Posted by Slowhawk
I like the turbo but a Procharger D1 will easilly hit your goal.Probly be cheaper and will take alot less time to do.
LS1Tech Sponsor
Originally Posted by scottywheels
I was thinking F1A Don only because I eventually will build the motor down the road so I can run the bigger turbo pulley down for less boost for now...
