Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Speed density and Mass inspection.
Old May 7, 2007 | 04:45 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Speed density and Mass inspection.
It passes no problem.Had 2 cars pass legit with the plug in test with no MAFs.
Old May 7, 2007 | 05:38 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Thats awesome, seemed for a while a hurdle for those running ODBII pcms.
Old May 7, 2007 | 05:42 PM
Slowhawk's Avatar
LS1Tech Sponsor
It was never a hurdle,we've had all our tuned cars pass that run MAF's. The big question was mafless since there is a permanent code.
Old May 7, 2007 | 05:44 PM
JL ws-6's Avatar
Race your car!
intresting.. something else to try one of these days in that case.
Old May 7, 2007 | 05:48 PM
Internet Mechanic
Thats what mean... In CT if there is a code like a MAF that will fail emissions, so it saves in the hassel of retuning to get though ever 2 years.
Old May 7, 2007 | 05:50 PM
ace68's Avatar
it passes in RI also, just folow the steps in the tutorial that comes with the so???are.
Old May 7, 2007 | 05:51 PM
ace68's Avatar
so???are?
Old May 7, 2007 | 05:52 PM
ace68's Avatar
weird why does question marks pop up in s-o-f-t-w-a-r-e
Old May 7, 2007 | 06:01 PM
badpewter-z's Avatar
LS1TECH Sponsor
yes it does pass
Old May 7, 2007 | 06:05 PM
DannoWS6's Avatar
Sweet I'm interested.
Old May 7, 2007 | 08:30 PM
8ALTNG's Avatar
It passes and I actually got a free inspection out of it
Old May 7, 2007 | 09:35 PM
Speedy0009's Avatar
Well, toss my car into the mix... No more MAF for me as of the passed day or two. Thanks Don!
Old May 7, 2007 | 10:10 PM
Slowhawk's Avatar
LS1Tech Sponsor
Once your car is tuned SD you'd wonder why you didn't do it first thing with that motor.For big motor/cam setup's SD should be mandatory.It runs 100% better.
Old May 7, 2007 | 10:38 PM
Speedy0009's Avatar
Does that mean my car should feel even better, besides the addition of the new power?? Throttle response is a given but what else to expect? Or just more so, on the big motor/cam set-up's?
Old May 8, 2007 | 04:39 AM
JL ws-6's Avatar
Race your car!
If the shop has some free time this season maybe I'll have them give it a try and see what they can do with it..... but for now I won't worry about it. Just gutting the cats seemed to help alot.
Old May 8, 2007 | 04:59 AM
Slowhawk's Avatar
LS1Tech Sponsor
For your FI it will feel stronger and more precise.If you add boost it will self adjust up to 15lbs.SD works awesome for Cammed FI or turbo setup's. Marcels car drives like stock with a cam,Mike can adjust his Turbo from 8lbs to 15lbs and timing -A/F adjusts automaticly unlike a MAF car.
Old May 8, 2007 | 07:15 AM
Speedy0009's Avatar
Oh no, that may have been bad to tell me.. They make smaller pullies for the D-1SC... DOH... I found someone selling a 3.75" just last night too.
Good to know though... Thanks Don!
Old May 8, 2007 | 07:25 AM
Slowhawk's Avatar
LS1Tech Sponsor
I'm thinking of opening up the intake and the cat-back sounds weak which could hurt power.
Old May 8, 2007 | 09:19 AM
Speedy0009's Avatar
Yeah I stated it on the GTO board that I figured at this point the factory cat-back may be choking it a bit... someone had previously suggested I ditch it for custom magnaflows... I am thinking sweet thunder chambered mufflers too allow more room for a larger diameter one piece drive shaft!
Opening the intake up... I have no idea how we'd fit 4" pipe in there...it's 3.5" already...?? If there's a will there's a way!
Old May 8, 2007 | 09:48 AM
Slowhawk's Avatar
LS1Tech Sponsor
Stock exhaust--------- ***
I wonder why it's short on power
