Clutch question?
I don't know anyone that has put an ls7 in a car, but it's a viable option if ya aren't gonna race much I'd think
I've seen almost every brand clutch out there weld itself or completely grenade with these driving technique's.
If a car/driver has alot of problems welding SPECs then a LS7 will burn up or explode the friction material.
Dont feel bad im at the clutch cross roads now, I cant be racing the car until it gets done, but at least it drives mint so I can cruise the whole summer.
So, my question is, does the LS7 take the abuse at the track? I don't want to downgrade, but I have just seen a lot of people recommending these. And by abuse I mean launching by dumping the clutch at 6K.
One of those tcs reversal modules wouldn't be a bad idea either... I actually stick a sticky note on the dash that says "TCS OFF" at the track just so I don't forget. At least until it's all ripped out completely LOL.
Jay- that really wouldnt be a bad idea. It is just waiting around, and turning the car on and off in the staging lanes that I forget to turn the TCS back off again
Steph you probably should do this too, I bet the fluid is black. Everyone I've had do this always says it feels a ton better afterwards. The slp tcs reversal module is like 70 bucks new, ya might be able to find a used one in the for sale section for less... but the sticky note, cost about a penny
Didn't you replace it at the end of last year? The 3I was an awesome clutch in my Vette.I burn't the hell out of it. Launch at 5500-6000rpm with serious clutch slip to pull 1.60's on the DR's.
Either way,if it sticks once it needs to be taken out and atleast the disk needs to be changed.
No matter what clutch you go with it's a good idea to replace the master and slave and use some fresh fluid. I like DOT 4.
Couple questions: Are you using a line lock while doing your burnouts?
I've seen plenty of people burn up their clutches from power braking and line locks are much cheaper than clutches.
Are you doing your burnouts near the water and not in the rubber?
I've also seen many people hurt their clutches by pulling too far up into the track prep and try to do burnouts.
Good luck getting everything straightened out.
my cousin has a spec 3, old school in his car for the last 10,000 miles and he drives HARD!!! with spray and all, round and round at the track (camaro firebird shoot out, i thought it was nascar!!) he has no issues, we are replacing it because it is getting worn, and he is doing a 12 bolt and more spray so i think it will be on its last leg, but i think the clutch is fine.
i have an ls7 for my vett, just havent put it in yet, but they are nice as well, i did one in my buddies bolt on with great luck, and it is much better then spec street wise, just be sure to put the spacer in
Did I ever say it wasn't user error? I thought I kind of made that clear my second post. I am fully aware that it doesn't just weld like that. If I didn't make that point clear enough: THIS CLUTCH WELDED BECAUSE OF MY ERROR IN DOING A BURNOUT. When I did the burnout, I reved the car to the point that it hit rev limiter, I let off the gas TOO MUCH (my error), the tires started to hook and the car started to bogg, I pulled out and it was stuck. I can see where you misinterpreted me. I meant to say I remember others saying they had the problem with the 3 before with it welding, and I remember Don saying when SPEC came out with the 3+ that SPEC said the new tech in the clutch should make it less common for them to weld. This again, was 2 years ago.
Anyway, I am going to have the flywheel refinished.
Don, this happened before when I was at the track with you. Just because it welded like that, do you suggest getting a new clutch? I thought it would be toast. I mean, I've had no problems what so ever since that one time until this weekend. And I did not change it last year, it is still the same clutch you put in. Maybe we will just take it out and see what it looks like, since I do believe the flywheel will need to be refinished.
