Comp r lifters = JUNK...
Good thing is the shortblock isnt hurt...
180 psi in all holes and only 3% leakdown so that good news..
Engine it apart and waiting for the cam to come from Comp.
We also went with the Crane Solid Rollers for the LT1,nice piece...
We went with a small solid roller but a little bigger than the old hyd roller
Specs are (244-250 585-591)
Lorenzo from fast flow is finishing up the Victor Jr as I write this post and will be getting it back from him by next wed....Cam,gaskets will be here by wed too as will the new lifters...
Next Sat. the engine is getting put back together and within 2 weeks its getting retuned and hit with nitrous....
Car will be at Atco the 1st week it opens up....
yeah i agree that turbo 408 car i just built has morels... as soon as i started the car up i could hear the lifter was dead..... so i had to take it back apart and replace it.... and its not like i can really make the customer pay for that either... it sucked...
So let me get this right....
Are you guys saying that the Old Comp-R's are good and the new ones are junk?
Shouldn't it be the other way around...in other words they were junk but now they have fixed the problems?
If what you are saying is true, what is the best Hyd. Roller lifter to get?
How are the GM Racing lifters used in the CTSV-R road race car?
Thanks
Thanks
BUt that that time Comp had already ceased production on that lifter and was in process of finding a new manufacture where I couldnt even buy a set of the old one with out doing some heavy searching. I was running a VERY mild hotcam (emission reasons) and standard replacements worked quite fine.
Here is a timeline for you from what I had researched back 5 yrs ago....
Pre-2003 Comp R's = Good
2004-2006 Comp R's = Junk
As for any revisements, I havent researched it, I havent ran a LT1 getting close to 2 years.
At the time I put a custom Bret Baur cam in where him and Lloyd recommended the Morels and they had worked fine.
The NEWER LSX lifters had not been avalible but it seems they they are the new rage, they can handle alot of spring pressure and are cheaper then Morels (500+).
What I am saying is you should do some research in the LT1 forum here or over on cz28.com for the caddy lifters.
That is a good idea.
I am still running my stock lifters and am just waiting for them to fail.
My limiter is set at 6800 rpm. (I shift my 4L60-E at 6,500)
So those will probably be fine for me.
My lift is no where near .650 either.
I have an LS1 car.
Is this post about LS1 roller lifters or LT1 rollers?
(JS referred to LT1 several times now?)
Thanks
Luckilly I work on alot of different cars and see different problems. Would still prefer the Morels over Comp R's though.
