Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
3.4 Whipple Build
Old Jun 9, 2008 | 04:38 PM
Frans96SS's Avatar
Default 3.4 Whipple Build
Sorry to get you guys excited but its not on an LSX car. A good freind of mine blew his car up 11 days after he bought it. It had 20k miles on it with a 2.2 KB, Solid Axle ect.
well instead of just fixing the short block we decided to go alittle overboard..
We did Custom Ross Pistons, stock Rod with ARP 2000 Bolt, new set of ARH headers, 3.4 Whipple, new clutch and 26 spline input shaft, Complete new fuel system ect.
car made just under 600 before. We are hoping for alittle more this time around.
Old Jun 9, 2008 | 06:17 PM
Slowhawk's Avatar
LS1Tech Sponsor
Should make some good power.We did a stang with the same blower,ported intake to the blower and have got almost 800rwhp so far.(built shortblock)Pain to get that pass side fuel rail in there.
Old Jun 9, 2008 | 08:11 PM
351carlo's Avatar
That's my car.
It's got the latest Gen II Rotors, revised inlet with hand ported radius section and then I deleted the EGR and added another 2 inches of inlet on the back end. If you look at the first picture you can see the weld line.
As for fuel rails, it has the billet Fore rails, and the ONLY way to get them in there is to install it in one piece. They actually didn't fit, we had to grind the inlet on the blower to get them to fit.
I'd like to see 800rwhp... maybe a couple more.
Old Jun 13, 2008 | 10:02 AM
White.Lightning's Avatar
Looks go so far. Get her tuned and post some #'s!!!
Old Jun 13, 2008 | 10:15 AM
Frans96SS's Avatar
haha your deff right on that.... the last injector took some time to get clipped in.
Old Jun 13, 2008 | 10:23 AM
sciff5's Avatar
So what does an 800whp twin screw blower setup equate to approx on the track?
Old Jun 13, 2008 | 10:26 AM
Frans96SS's Avatar
it should easily go 9's i would think.... this car is a solid rear i dont know what the one slowhawk built was.
Old Jun 13, 2008 | 11:11 AM
sciff5's Avatar
Whats the weight of the car and what do you think she'll trap approx?
Old Jun 13, 2008 | 11:13 AM
Frans96SS's Avatar
im not sure its at least 3500 pounds... it should trap 140+
Old Jun 13, 2008 | 12:04 PM
sciff5's Avatar
Wow thats strong.. I still dont know which would be a better choice, the whipple or kb 2.8 for an Ls1. I am far off from going FI but in the future I might step up to a turbo or twin screw for my ls1 rx7. The twin screw would prob be a lot easier to insall.
Old Jun 13, 2008 | 02:34 PM
Frans96SS's Avatar
634 hp 605 tq on a mustang dyno. 20.5 psi boost and not much timing at all.... we are gonna leave it this way for like 800-1k miles them add a couple more degrees of timing. It should make about 700 on pump gas with more timing.
Old Jun 13, 2008 | 07:56 PM
sciff5's Avatar
20.5 psi on pump gas?? is this with methanol or something?
Old Jun 14, 2008 | 09:31 AM
SSlow1's Avatar
Nice work Fran.....As usual
Old Jun 14, 2008 | 09:41 AM
sleeperstyle's Avatar
whenever he is ready...
glad to see you guys got it together and it runs good
Old Jun 14, 2008 | 10:34 AM
The laughing gas isn't in your car anymore......or is it???
Old Jun 14, 2008 | 11:34 AM
Dynotune04's Avatar
If its TJ's car which im 99% sure it is its still an irs. but plans are in the works for the solid swap
Old Jun 14, 2008 | 03:08 PM
351carlo's Avatar
Yea Fran did a great job with this build.
With the engine, trans, wiring harness, fuel system, exhaust and half the interior being out of the car, there was only ONE hiccup after we got it running and on the dyno. The auxiliary blower pulley assembly has an idler built in, and somehow the bolt backed out a bit on the first dyno pull and the belt walked 2 ribs. It was only because I supplied the wrong bolt and idler pulley accidentally (From my previous aftermarket setup, we went back to a stock lower).
Car is still running great. Took it to Philly today and going to the Vineland Cruise tonight.
Car is around 3600lbs without me in it, full interior, 17" rims, full stereo with sub and amp, no weight reduction. Solid rear, and a steady torque curve of 590-607 with us cutting it short. Like Fran said, it should go 9's without much work and trap at least 142-143.
Thanks for the interest. I'll be in Vineland tonight if you're around come say hi.
Carlo
Old Jun 14, 2008 | 03:16 PM
SSlow1's Avatar
Congrads Carlo I met you at Fran's shop the other day in the NBM SS.
Old Jun 15, 2008 | 01:26 AM
351carlo's Avatar
Hey Mike thanks. What was up with Pizza U's drive-by tonight, can't stop and say hi? I know you're too cool for us Mustang folk.
Hope the car runs well.
Old Jun 15, 2008 | 01:50 AM
SSlow1's Avatar
I thought that was you .... sorry man I had to pee When I came back around you were gone. I was going to ask you for a ride. Oh and NO I'm not too cool LMAO
