Florida Members Fun, sun and LS1's
Any one have a chris1313 ramair?
Old 01-14-2011 | 03:48 PM
Trevor.j's Avatar
Default Any one have a chris1313 ramair?
Wonder if anyone has this ramair kit? I need to take measurements to see if it will clear my big trannycooler.. I need the one without ac. Or does any one have exact measurements? I couldn't find any
Old 01-17-2011 | 03:49 PM
TurboStangJON's Avatar
I'd PM Chrs1313 and ask him for exact measurements. I just put the Non A/C version on my car and had to move my little B&M cooler I had on the radiator. Are you going to try and put it between the ram air and the radiator? In my opinion there's no room to put anything in front of the radiator except the ram air. I live in St. Cloud and if you're bored sometime you can take some measurements.
Old 01-17-2011 | 04:33 PM
Trevor.j's Avatar
Well I already have my huge b&m cooler mounted dope style. I don't think it will be in the way. I know it will fit between the rad and front support. I just don't know if the bottom is gonna fit where I have my cooler mounted. And I may take you up on that offer to get some Measurements. Just got to see when I'm off next.
Old 01-17-2011 | 05:21 PM
If it's dope mounted off to the side of the radiator support it will fit. I went outside and snapped a quick picture with my phone for reference of where the ram air sits. I don't have an air dam but I believe it comes down lower than a factory air dam. I just installed it yesturday and I'm still waiting to find out the results. Hopefully 10's!
Old 01-17-2011 | 06:40 PM
Trevor.j's Avatar
Oh yea I should be fine! The way my cooler sits since it's so big is half way onto the stock air dam. But those pics help alot! I really appreciate it! And every one I talk to says that they pick up atleast 2-3mph going through traps! And they noticed the big difference on the highway.
Old 01-17-2011 | 06:50 PM
No problem! I talked to Chris and he said 2MPH is the norm. Also, I told him I see why because this freaking thing is huge. I'd be happy with 2MPH because it should put me in the 125-126 range on motor.
Old 02-15-2011 | 10:37 PM
chrs1313's Avatar
hey guys let me know if you have any other questions...also remember to seal the intake up to the lid assembly using the supplied weather stripping (for the front stock slit, stacked 3 high works great)...Also the lid to the air filter can be another spot where air escapes...The rest i sealed up nicely with clear silicone...This will give the best gains...only let it breathe from the bottom...
pm me if you have any questions...thanks
if you were trapping 120 before with a stock setup you will have no problem getting 2mph at the min...
